Old 11-16-2009, 05:26 PM
Rogue's Avatar
Rogue Rogue is offline
Vehicle: 2009 Ram 1500 Crew Cab 4x4
Trim Level: TRX, 25T pkg w 5.7 L
Rep:22
Rogue is on a distinguished road
Send a message via ICQ to Rogue
Default Just had these sent to me
SERVICE BULLETIN:TB-18-016-09 NHTSA ITEM NUMBER:10030706
MFG Bulletin Date: 20090515
Component: ELECTRICAL SYSTEM:WIRING
Bulletin Summary: DODGE: MIL ILLUMINATION OR STORED DIAGNOSTIC TROUBLE CODE (DTC) FOR P1004 OR 02016 OR 02017. THIS INVOLVES REPLACING THE SHORT RUNNER VALVE (SRV), SRV CONNECTOR, WIRING PIGTAIL, AND ADDING A NEW STUD FOR A TIE STRAP. THE SRV WIRING TAKEO
Date added to datbase: 20091113
You can get EVERY Technical Service Bulletins (TSB) in its entirety ever issued by the manufacturer to its dealers for this model car plus ALL future TSBs issued for the next 12 months. [Purchase] [What you'll get] [What is a TSB]
2 Engine and Engine Cooling System Reports Show Reports in this Group Close
Yes, include on Custom Report SERVICE BULLETIN:TB-18-016-09 NHTSA ITEM NUMBER:10030706
Component: ENGINE AND ENGINE COOLING:ENGINE
Component: ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:MANIFOLD/HEADER/MUFFLER/TAIL PIPE
Old 11-24-2009, 12:35 PM
LS Eater's Avatar
LS Eater LS Eater is offline
Vehicle: 2011 Ram Crew Cab Cummins
Color: Pearl White
Rep:12
LS Eater is on a distinguished road
I was told my 09 has 3 Rapid Respose items. ( 09020, 09041, and 09042) anyone know what these are? i know 09020 is rear axle breather but no clue on the other 2...
Old 12-10-2009, 09:12 PM
Rogue's Avatar
Rep:22
Default Newest list from AllData.com
Automotive Recall and Technical Service Bulletin Titles for 2009 Dodge Truck RAM 1500 Truck 4WD V8-5.7L.
TSB Number & Issue Date TSB Title
J08 JUN 09 Recall - Potential Clutch Pedal Link Separation (Canada)
H46 JUN 09 Recall - Steering Linkage Defects
J08 MAY 09 Recall - Clutch Pedal Linkage Rod Defect
H36 MAY 09 Recall - Drag Link/Steering Damper Bracket Defects
J04 MAR 09 Recall - Incorrect VECI Label Installed At Production
18-019-09 JUL 09 Engine Controls - MIL ON/Multiple DTC's Set
08-10-09 JUN 09 Parking Assist System - False Objects Indicated
18-016-09 MAY 09 Engine Controls - MIL ON/DTC's P1004/P2016/P2017
23-015-09 MAY 09 Body - Door Rubs On Fender When Opening/Closing
23-012-09 MAY 09 Body - Hood Creaking And Squeaking Sound
23-011-09 APR 09 Interior - Front Seat Clicking/Squeaking/Creaking Noises
08-008-09 APR 09 Wipers/Washers - Washer Solvent Level Sensor Weepage
22-001-09 MAR 09 Wheels/Tires - Vehicle Vibration/Shake At Highway Speed
08-003-09 FEB 09 Audio System - Radio Inop. After Battery Disconnect
18-041-08 DEC 08 Engine Controls - ECM Update For Spark Knock/Vibration
21-022-08 OCT 08 A/T - Converter Shudder On Vehicles With Less Than 4K Mi
21-021-08 SEP 08 A/T - Repair/Replacement Guidelines
Old 12-10-2009, 09:36 PM
Rep:1885
Not all of those recalls apply to the 2009 Ram. Only the J-04 (VECI label), J-06 (washer fluid level sensor), and J-12 (Flash HVAC control head) currently apply.
Old 12-17-2009, 06:02 PM
SPEEDFREAK's Avatar
SPEEDFREAK SPEEDFREAK is offline
Vehicle: 2010 RAM R/T
Trim Level: 450HP & 450TQ
Color: SPEED WHITE
Rep:180
SPEEDFREAK has a spectacular aura aboutSPEEDFREAK has a spectacular aura about
Default 2009 tsb
There were 2 tsb that the dealer fixed when i took my truck in to fix the rear gear it was wining. Had to order new 4.10 gear set. Tsb 1-- rear left tail light reseal it. Tsb 2-- rubber trim on driver door at the bottom needed fixing. Thats all for now.
k&N CAI, 3 1/2" 90 on CAI at TB, 85mm BBK TB,denso sp,180stat,syn oileng & rear gr,Catchcan, Addco sway bars f&r
1 3/4"amer rac hders high flowcats, 2 1/2" H pipe dul 2 1/2" piping, Diablo CT, Bilstin, Mcdrop 2/4,1deg cam 295/45-20bfgkdw,efan,13.4gtech
Old 12-27-2009, 08:29 PM
Rogue's Avatar
Rep:22
Default What vehicle they are for
These TSB's are for the 2009 Dodge Ram 1500 4 wheel drive. I apologize for any confusion.
Old 12-30-2009, 05:41 PM
Rep:2657
i took in my 2009 Ram SLT 1500 5.7 Hemi 2 wheel drive & told the service manager that my check engine light stayed on & that the remote start will start the engine, BUT, that the engine shuts off almost immediately. they cleared the code & told me to return the next day for repairs, that it would take 6 hours
TSB 18-016-09 they replaced 53022137AG short runner valve, associated wiring, retaining strap, stud, tape, & adhesive lock & seal
Old 01-19-2010, 10:03 PM
Rogue's Avatar
Rep:22
Default From my car stats
SERVICE BULLETIN:TSB-09-041 NHTSA ITEM NUMBER:10030926
MFG Bulletin Date: 20090709
Component: SERVICE BRAKES, AIR:ANTILOCK:CONTROL UNIT/MODULE
Bulletin Summary: CHRYSLER: DODGE-APPROXIMATELY 125,182 VEHICLES, EQUIPPED WITH ESP SALES CODE (BNB ) HAVE A CONDITION THAT MAY SET THE ABS, ESP, AND/OR BASE BRAKE WARNING LAMP ON IN THE CLUSTER WITH CODE C2200. DEALERS ARE REQUIRED TO FLASH THE ABS MODULE
Date added to datbase: 20091222
Yes, include on Custom Report SERVICE BULLETIN:TSB-09-041 NHTSA ITEM NUMBER:10030926
Component: SERVICE BRAKES, HYDRAULIC:ANTILOCK:CONTROL UNIT/MODULE
Component: ELECTRICAL SYSTEM: SOFTWARE
NUMBER:10031724
MFG Bulletin Date: 20090924
Bulletin Summary: DODGE/CHRYSLER: WIRE HARNESS ROUTING. A NUMBER OF VEHICLES SHIPPED WITH AN ENGINE WIRE HARNESS ROUTED ON THE WRONG SIDE OF THE PCV TUBE. DEALERS ARE REQUIRED TO INSPECT AND IF NECESSARY REROUTE THE HARNESS PROPERLY. *PE
Date added to datbase: 20100113
Yes, include on Custom Report SERVICE BULLETIN:SB-09-002-09 NHTSA ITEM NUMBER:10031004
MFG Bulletin Date: 20090613
Component: ENGINE AND ENGINE COOLING:ENGINE:GASOLINE:TURBO-CHARGER
Bulletin Summary: DODGE: REVISED DIAGNOSTIC AND REPAIR PROCEDURES FOR DTC P2262-TURBOCHARGER BOOST PRESSURE NOT DETECTED-MECHANICAL. RECENT PCM CALIBRATION UPDATES HAVE IMPROVED THE ROBUSTNESS TO THIS DTC THROUGH UPDATED DIAGNOSTIC STRATEGIES.
Date added to datbase: 20091230
Component: ENGINE AND ENGINE COOLING:ENGINE:OTHER FUEL TYPES:TURBO-CHARGER
RECALLS
Air Conditioner, Heater, Ventilation Reports Show Reports in this Group Close
Yes, include on Custom Report NHTSA Recall Campaign Number: 09V158000
Component: AIR CONDITIONER
Details: CHRYSLER IS RECALLING 36,793 MY 2009 DODGE RAM LIGHT DUTY PICKUP TRUCKS EQUIPPED WITH MANUAL TEMPERATURE CONTROL (MTC) ONLY. THE SOFTWARE PROGRAMMED INTO THE HEATING VENTILATION AND AIR CONDITIONING MODULE MAY CAUSE THE WINDSHIELD DEFROSTING AND DEFOGGING FUNCTIONS TO BECOME INOPERATIVE.
Consequence: THIS CAN DECREASE THE DRIVERS VISIBILITY UNDER CERTAIN DRIVING CONDITIONS AND RESULT IN A CRASH WITHOUT WARNING.
Corrective Action: DEALERS WILL REPROGRAM THE HVAC MODULE FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN ON OR BEFORE AUGUST 3, 2009. OWNERS MAY CONTACT CHRYSLER AT 1-800-835-1403.
Units Potentially Affected: 36793
Recall Initiated By: MFR
Date added to NHTSA datbase: 05/08/2009
1 Brake Reports Show Reports in this Group Close
Yes, include on Custom Report NHTSA Recall Campaign Number: 10V009000
Details: CHRYSLER IS RECALLING MODEL YEAR 2010 CHRYSLER SEBRING; DODGE AVENGER AND NITRO; JEEP LIBERTY, COMMANDER AND GRAND CHEROKEE; AND MODEL YEAR 2009-2010 DODGE RAM TRUCK. THESE VEHICLES MAY HAVE BEEN BUILT WITH AN IMPROPERLY FORMED OR MISSING BRAKE BOOSTER INPUT ROD RETAINING CLIP.
Consequence: THIS COULD RESULT IN BRAKE FAILURE WITHOUT WARNING WHICH COULD CAUSE A CRASH.
Corrective Action: CHRYSLER WILL REPLACE THE BRAKE BOOSTER INPUT ROD RETAINING CLIP FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN DURING JANUARY 2010. OWNERS MAY CONTACT CHRYSLER AT 1-800-853-1403.
Units Potentially Affected: 24177
Date added to NHTSA datbase: 01/11/2010
Yes, include on Custom Report NHTSA Recall Campaign Number: 09V078000
Component: POWER TRAIN:CLUTCH ASSEMBLY:PEDAL/LINKAGE
Details: CHRYSLER IS RECALLING 504 MY 2009 DODGE RAM 2500/3500 PICKUP TRUCKS HEAVY DUTY CAB CHASSIS WITH MANUAL TRANSMISSION AND POWER ADJUSTABLE PEDAL PACKAGE. THE CLUTCH PEDAL CONNECTING ROD TO THE CLUTCH MASTER CYLINDER MAY SEPARATE FROM THE MASTER CYLINDER. THIS MAY NOT ALLOW DISENGAGEMENT OF THE CLUTCH WHEN THE PEDAL IS DEPRESSED, WHICH COULD RESULT IN UNINTENDED VEHICLE MOVEMENT.
Consequence: INCREASED STOPPING DISTANCE AND ENGINE STALLING MAY OCCUR INCREASING THE RISK OF A CRASH.
Corrective Action: DEALERS WILL REPLACE THE CLUTCH MASTER CYLINDER HYDRAULIC SYSTEM FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN DURING APRIL 2009. OWNERS MAY CONTACT CHRYSLER AT 1-800-853-1403.
Units Potentially Affected: 504
Date added to NHTSA datbase: 03/10/2009
Yes, include on Custom Report NHTSA Recall Campaign Number: 09E009000
Component: VISIBILITY:WINDSHIELD WIPER/WASHER
Details: CHRYSLER IS RECALLING 1,364 WINDSHIELD WIPER MODULES, P/N 55077098AJ, SOLD DURING THE 2008 AND 2009 CALENDAR YEAR FOR USE AS AFTERMARKET REPLACEMENT EQUIPMENT ON MY 2002-2009 DODGE RAM PICKUP TRUCKS. THESE WIPER MODULE ASSEMBLIES MAY BE SUSCEPTIBLE TO WATER INTRUSION THAT COULD RESULT IN PARTIAL OR COMPLETE LOSS OF WINDSHIELD WIPER CAPABILITY.
Consequence: WHEN THE WIPER SYSTEM FAILS, THE OPERATOR WILL HAVE REDUCED VISIBILITY WHICH COULD RESULT IN A CRASH.
Corrective Action: DEALERS WILL REPLACE THE WIPER MODULE ASSEMBLIES WITH VENTED WIPER MOTOR HOUSINGS FREE OF CHARGE. THE SAFETY RECALL BEGAN ON AUGUST 28, 2009. OWNERS MAY CONTACT CHRYSLER AT 1-800-853-1403.
Units Potentially Affected: 1364
Date added to NHTSA datbase: 03/13/2009
[FILE] your own complaint about this model car.
Yes, include on Custom Report NHTSA Recall Campaign Number: 09V084000
Component: VISIBILITY:WINDSHIELD WIPER/WASHER:MOTOR
Details: CHRYSLER IS RECALLING 65,896 MY 2008-2009 LIGHT AND HEAVY DUTY DODGE RAM PICKUP TRUCKS. THE WINDSHIELD WIPER MODULE MOTOR ASSEMBLY MAY BE SUSCEPTIBLE TO WATER INTRUSION THAT COULD RESULT IN PARTIAL OR COMPLETE LOSS OF WINDSHIELD WIPING CAPABILITY.
Corrective Action: DEALERS WILL REPLACE THE WIPER MODULE ASSEMBLIES WITH VENTED WIPER MOTOR HOUSINGS FREE OF CHARGE. THE SAFETY RECALL BEGAN ON AUGUST 17, 2009. OWNERS MAY CONTACT CHRYSLER AT 1-800-853-1403.
Units Potentially Affected: 65896
Date added to NHTSA datbase: 03/12/2009
Old 01-19-2010, 10:12 PM
Rogue's Avatar
Rep:22
Default These are the TSB's for 2009 Dodge Ram 1500
Complaints 2
Recalls 0
Bulletins 7
Investigations 0
1 Electrical System Reports Show Reports in this Group Close
3 Engine and Engine Cooling System Reports Show Reports in this Group Close
Yes, include on Custom Report SERVICE BULLETIN:J-04 NHTSA ITEM NUMBER:10028833
MFG Bulletin Date: 20090301
Component: ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:EMISSION CONTROL
Bulletin Summary: DODGE: A NON APPLICABLE VEHICLE EMISSION CONTROL INFORMATION (VECI) LABEL WAS INADVERTENTLY INSTALLED. CSC LETTER WAS RECEIVED. *PE
Date added to datbase: 20090601
Component: EQUIPMENT:OTHER:LABELS
Yes, include on Custom Report SERVICE BULLETIN:SB-09-035 NHTSA ITEM NUMBER:10030346
MFG Bulletin Date: 20090529
Component: STRUCTURE:BODY:TAILGATE
Bulletin Summary: CHRYSLER/DODGE: TAILGATE SPOILER MODIFICATION. VEHICLES MAY REQUIRE THE ADDITION OF TWO SIDED TAPE TO THE INBOARD EDGE OF THE TAILGATE SPOILER TO PREVENT THE SPOILER FROM TEARING OFF THE TAILGATE WHEN CARGO IS UNLOADED.
Date added to datbase: 20090923
1 Suspension, Wheel, Tire Reports Show Reports in this Group Close
Yes, include on Custom Report SERVICE BULLETIN:SB-22-0001-0 NHTSA ITEM NUMBER:10028944
MFG Bulletin Date: 20090307
Component: TIRES
Bulletin Summary: CHRYSLER: VEHICLE VIBRATION OR SHAKE AT HIGHWAY SPEED: THE TIRES ARE FLAT SPOTTED DUE TO SHIPPING OR SITTING IN THE LOT FOR AN EXTENDED PERIOD, THE VEHICLE VIBRATION WILL GO AWAY AFTER THE TIRES ARE WARMED UP, (NORMALLY 10 TO 20 MILES OF HI
Date added to datbase: 20090608
COMPLAINTS
2 Structure Reports
ODI Case Number: 10269654
Details: THE CHROME TRIM RING AROUND THE SHIFTER ON THE CONSOLE MOUNTED SHIFTER REFLECTS THE SUN RIGHT BACK INTO YOUR EYES DURING CERTAIN TIMES OF THE DAY. THIS IS VERY DANGEROUS TO HAVE THIS GLARE IN YOUR VISION. I MUST COVER THAT AREA WITH MY HAND TO BLOCK THE REFLECTION. I CANNOT HAVE BOTH OF MY HANDS ON THE STEERING WHEEL WHEN THIS HAPPENS. I CANNOT LEGALLY TINT MY FRONT SIDE WINDOWS OR THE FRONT WINDSHIELD TO LESSEN THE LIGHT. THIS IS A DANGEROUS DESIGN FLAW. *TR
Occurrences: 1 Injuries: 0
Fail Date: 05/20/2009 Deaths: 0
Date added to datbase: 5/21/2009
ODI Case Number: 10260225
Component: LATCHES/LOCKS/LINKAGES:TAILGATE:LATCH
Details: TL*THE CONTACT OWNS A 2009 DODGE RAM 1500 LARAMIE. UPON PURCHASING THE VEHICLE IN 2008, THE CONTACT WAS INFORMED THAT THE VEHICLE WOULD BE COMPATIBLE WITH A CAB. HE HAD A CAB INSTALLED ON THE VEHICLE; HOWEVER, THE TAILGATE LOCKING MECHANISM WOULD NOT OPERATE WITH THE EXTENDED CAB ATTACHMENT. THE DEALER STATED THAT THE EXTENDED CAB WAS NOT COMPATIBLE WITH THE VEHICLE AND WOULD TRY INSTALLING ANOTHER ONE. THE DEALER LATER STATED THAT THEY DID NOT HAVE THE AUTHORITY TO INSTALL A SECOND CAB. THE FAILURE AND CURRENT MILEAGES WERE LESS THAN 4,000.
Fail Date: 01/10/2009 Deaths: 0
Date added to datbase: 2/27/2009
Old 03-16-2010, 09:00 PM
Rogue's Avatar
Rep:22
Default Current as of 3/16/10 from ALLDATAdiy.com
J12 JUL 09 Recall - HVAC Control Module Programming
J06 OCT 09 Campaign - Windshield Washer Fluid Level Sensor
08-018-09 NOV 09 Engine Controls - TIPM Update For ECM PROM Update Issues
26-001-09 SEP 09 Maintenance - Fluid Flushing Information
14-001-09A SEP 09 Fuel System - Difficult Fuel Fill/Nozzle Shuts Off
22-002-09 JUL 09 Wheels/Tires - Chrome Clad Wheel Balancing Information
