Old 05-01-2010, 06:27 PM
Rogue's Avatar
Rogue Rogue is offline
Vehicle: 2009 Ram 1500 Crew Cab 4x4
Trim Level: TRX, 25T pkg w 5.7 L
Rep:22
Rogue is on a distinguished road
Send a message via ICQ to Rogue
Default As of May 1st, 2010
Automotive Recall and Technical Service Bulletin Titles for 2009 Dodge Truck RAM 1500 Truck 4WD V8-5.7L.
TSB Number & Issue Date TSB Title
J12 JUL 09 Recall - HVAC Control Module Programming
J08 JUN 09 Recall - Potential Clutch Pedal Link Separation (Canada)
H46 JUN 09 Recall - Steering Linkage Defects
J08 MAY 09 Recall - Clutch Pedal Linkage Rod Defect
H36 MAY 09 Recall - Drag Link/Steering Damper Bracket Defects
J04 MAR 09 Recall - Incorrect VECI Label Installed At Production
J06 OCT 09 Campaign - Windshield Washer Fluid Level Sensor
18-003-10 JAN 10 Engine Controls - MIL ON/DTC P1004/P2016/P2017
24-004-09 NOV 09 A/C - Hissing Noise With A/C ON
08-018-09 NOV 09 Engine Controls - TIPM Update For ECM PROM Update Issues
26-001-09 SEP 09 Maintenance - Fluid Flushing Information
14-001-09A SEP 09 Fuel System - Difficult Fuel Fill/Nozzle Shuts Off
22-002-09 JUL 09 Wheels/Tires - Chrome Clad Wheel Balancing Information
18-019-09 JUL 09 Engine Controls - MIL ON/Multiple DTC's Set
08-10-09 JUN 09 Parking Assist System - False Objects Indicated
18-016-09 MAY 09 Engine Controls - MIL ON/DTC's P1004/P2016/P2017
23-015-09 MAY 09 Body - Door Rubs On Fender When Opening/Closing
23-012-09 MAY 09 Body - Hood Creaking And Squeaking Sound
23-011-09 APR 09 Interior - Front Seat Clicking/Squeaking/Creaking Noises
08-008-09 APR 09 Wipers/Washers - Washer Solvent Level Sensor Weepage
22-001-09 MAR 09 Wheels/Tires - Vehicle Vibration/Shake At Highway Speed
08-003-09 FEB 09 Audio System - Radio Inop. After Battery Disconnect
18-041-08 DEC 08 Engine Controls - ECM Update For Spark Knock/Vibration
21-022-08 OCT 08 A/T - Converter Shudder On Vehicles With Less Than 4K Mi
21-021-08 SEP 08 A/T - Repair/Replacement Guidelines
Old 07-28-2010, 07:36 PM
Rogue's Avatar
Rep:22
Default From Alldata
Old 07-28-2010, 07:51 PM
Rogue's Avatar
Rep:22
Default From mycarstats
Custom Report on
2009 Dodge RAM 1500
print
Created on: 7/28/2010
Report Type: BULLETINS
Warranty Expires On: Unknown
SERVICE BULLETIN:TB-18-016-09 NHTSA ITEM NUMBER:10030706
MFG Bulletin Date: 20090515
Component: ELECTRICAL SYSTEM:WIRING
Bulletin Summary: DODGE: MIL ILLUMINATION OR STORED DIAGNOSTIC TROUBLE CODE (DTC) FOR P1004 OR 02016 OR 02017. THIS INVOLVES REPLACING THE SHORT RUNNER VALVE (SRV), SRV CONNECTOR, WIRING PIGTAIL, AND ADDING A NEW STUD FOR A TIE STRAP. THE SRV WIRING TAKEO
Date added to datbase: 20091113
You can get EVERY Technical Service Bulletins (TSB) in its entirety ever issued by the manufacturer to its dealers for this model car plus ALL future TSBs issued for the next 12 months. [Purchase] [What you'll get] [What is a TSB]
Component: ENGINE AND ENGINE COOLING:ENGINE
SERVICE BULLETIN:J-04 NHTSA ITEM NUMBER:10028833
MFG Bulletin Date: 20090301
Component: ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:EMISSION CONTROL
Bulletin Summary: DODGE: A NON APPLICABLE VEHICLE EMISSION CONTROL INFORMATION (VECI) LABEL WAS INADVERTENTLY INSTALLED. CSC LETTER WAS RECEIVED. *PE
Date added to datbase: 20090601
Component: ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:MANIFOLD/HEADER/MUFFLER/TAIL PIPE
Component: EQUIPMENT:OTHER:LABELS
SERVICE BULLETIN:SB-09-035 NHTSA ITEM NUMBER:10030346
MFG Bulletin Date: 20090529
Component: STRUCTURE:BODY:TAILGATE
Bulletin Summary: CHRYSLER/DODGE: TAILGATE SPOILER MODIFICATION. VEHICLES MAY REQUIRE THE ADDITION OF TWO SIDED TAPE TO THE INBOARD EDGE OF THE TAILGATE SPOILER TO PREVENT THE SPOILER FROM TEARING OFF THE TAILGATE WHEN CARGO IS UNLOADED.
Date added to datbase: 20090923
SERVICE BULLETIN:SB-22-0001-0 NHTSA ITEM NUMBER:10028944
MFG Bulletin Date: 20090307
Component: TIRES
Bulletin Summary: CHRYSLER: VEHICLE VIBRATION OR SHAKE AT HIGHWAY SPEED: THE TIRES ARE FLAT SPOTTED DUE TO SHIPPING OR SITTING IN THE LOT FOR AN EXTENDED PERIOD, THE VEHICLE VIBRATION WILL GO AWAY AFTER THE TIRES ARE WARMED UP, (NORMALLY 10 TO 20 MILES OF HI
Date added to datbase: 20090608
SERVICE BULLETIN:SB-J-06 NHTSA ITEM NUMBER:10032711
MFG Bulletin Date: 20091001
Component: VISIBILITY:WINDSHIELD WIPER/WASHER
Bulletin Summary: DODGE: THE WINDSHIELD WASHER FLUID LEVEL SENSOR ON SOME TRUCKS MAY LEAK ALLOWING WASHER FLUID TO WICK THROUGH THE WIRING HARNESS TO THE AMBIENT TEMPERATURE SENSOR. THIS CAN DAMAGE THE AMBIENT TEMPERATURE SENSOR AND CAUSE ILLUMINATION OF T
Date added to datbase: 20100430
Component: VISIBILITY:WINDSHIELD WIPER/WASHER:SWITCH/WIRING
Old 08-21-2010, 05:00 PM
XxCRAZYBUDxX XxCRAZYBUDxX is offline
Vehicle: 2009 DODGE RAM 1500 4X4
Trim Level: LARAMIE
Color: DEEP WATER BLUE 2TONE
XxCRAZYBUDxX is on a distinguished road
Ventilated seatcover: I 2 have had a tearing problem.replaced 2xs at the dealers expense and they will keep replacing it in my opinion,untill the problem is solved...DO not let the dealer push you over...i dont and will not let them....
Old 08-27-2010, 12:36 AM
808 KUMA's Avatar
808 KUMA 808 KUMA is offline
Vehicle: 2009 Ram
Trim Level: SLT,Crew Cab,Ram Box
Color: Mineral Grey Metalic
Rep:111
808 KUMA will become famous soon enough808 KUMA will become famous soon enough
I don't see the TSB for the 3rd brake light gasket check and replace if leaking. It came out the same time as the door gasket checks, I believe. The dealership checked mine when I had it in to reprogram for the 20's way back in the spring.
Custom Grill,Airaid. E-3 plgs. Spintech catbck. Stainless Smittybuilt Nerf's. E-Z gate. Putco mirror cvrs. Fire & Ice LED tailgate strip. LED eng.bay lights. 20" Wheels. Ramheads LED's. Clear LED Tail lights. Fog Lights.15" Night Raider Strobe in lower grill. Chrome Diff. cover. Red brake-calipers. Polished drive shaft. MOPAR Soft Tonneau cover. Stainless pillar post covers. Mopar-Chrome gas cover. Stainless window-sill trim. Clear LED 3rd Brake Light. Mopar Slush-Mats. "Wet-Suit" type seat covers(Red-on-Black) Custom Ram-Strpe on rear fenders.
Old 09-02-2010, 11:40 PM
Rogue's Avatar
Rep:22
Default TSB's from Edmunds.Com
2009 Dodge Ram Pickup 1500 4dr Crew Cab SB (5.7L 8cyl 5A)
1.VISIBILITY:WINDSHIELD WIPER/WASHER
2.VISIBILITY:WINDSHIELD WIPER/WASHER:SWITCH/WIRING
3.ELECTRICAL SYSTEM:WIRING
4.SERVICE BRAKES, HYDRAULIC:ANTILOCK:CONTROL UNIT/MODULE
5.SERVICE BRAKES, AIR:ANTILOCK:CONTROL UNIT/MODULE
6.ELECTRICAL SYSTEM: SOFTWARE
7.ENGINE AND ENGINE COOLING:ENGINE:GASOLINE:TURBO-CHARGER
8.ENGINE AND ENGINE COOLING:ENGINE:OTHER FUEL TYPES:TURBO-CHARGER
9.STRUCTURE:BODY:TAILGATE
10.ENGINE AND ENGINE COOLING:ENGINE
11.ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:MANIFOLD/HEADER/MUFFLER/TAIL PIPE
12.ELECTRICAL SYSTEM:WIRING
13.ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:EMISSION CONTROL
14.EQUIPMENT:OTHER:LABELS
15.TIRES
Component Description:
1. VISIBILITY:WINDSHIELD WIPER/WASHER Bulletin Number: SB-J-06
Bulletin Date: Oct 2009
Vehicle: 2,009 Dodge Ram Pickup 1500
Summary:
DODGE: THE WINDSHIELD WASHER FLUID LEVEL SENSOR ON SOME TRUCKS MAY LEAK ALLOWING WASHER FLUID TO WICK THROUGH THE WIRING HARNESS TO THE AMBIENT TEMPERATURE SENSOR. THIS CAN DAMAGE THE AMBIENT TEMPERATURE SENSOR AND CAUSE ILLUMINATION OF T ( NHTSA ITEM NUMBER - 10032711 )
2. VISIBILITY:WINDSHIELD WIPER/WASHER:SWITCH/WIRING Bulletin Number: SB-J-06
Summary:
3. ELECTRICAL SYSTEM:WIRING Bulletin Number: RT-09-064
Bulletin Date: Sep 2009
Summary:
DODGE/CHRYSLER: WIRE HARNESS ROUTING. A NUMBER OF VEHICLES SHIPPED WITH AN ENGINE WIRE HARNESS ROUTED ON THE WRONG SIDE OF THE PCV TUBE. DEALERS ARE REQUIRED TO INSPECT AND IF NECESSARY REROUTE THE HARNESS PROPERLY. ( NHTSA ITEM NUMBER - 10031724 )
4. SERVICE BRAKES, HYDRAULIC:ANTILOCK:CONTROL UNIT/MODULE Bulletin Number: TSB-09-041
Bulletin Date: Jul 2009
Summary:
CHRYSLER: DODGE-APPROXIMATELY 125,182 VEHICLES, EQUIPPED WITH ESP SALES CODE (BNB ) HAVE A CONDITION THAT MAY SET THE ABS, ESP, AND/OR BASE BRAKE WARNING LAMP ON IN THE CLUSTER WITH CODE C2200. DEALERS ARE REQUIRED TO FLASH THE ABS MODULE ( NHTSA ITEM NUMBER - 10030926 )
5. SERVICE BRAKES, AIR:ANTILOCK:CONTROL UNIT/MODULE Bulletin Number: TSB-09-041
Summary:
6. ELECTRICAL SYSTEM: SOFTWARE Bulletin Number: TSB-09-041
Summary:
7. ENGINE AND ENGINE COOLING:ENGINE:GASOLINE:TURBO-CHARGER Bulletin Number: SB-09-002-09
Bulletin Date: Jun 2009
Summary:
DODGE: REVISED DIAGNOSTIC AND REPAIR PROCEDURES FOR DTC P2262-TURBOCHARGER BOOST PRESSURE NOT DETECTED-MECHANICAL. RECENT PCM CALIBRATION UPDATES HAVE IMPROVED THE ROBUSTNESS TO THIS DTC THROUGH UPDATED DIAGNOSTIC STRATEGIES. ( NHTSA ITEM NUMBER - 10031004 )
8. ENGINE AND ENGINE COOLING:ENGINE:OTHER FUEL TYPES:TURBO-CHARGER Bulletin Number: SB-09-002-09
Summary:
9. STRUCTURE:BODY:TAILGATE Bulletin Number: SB-09-035
Bulletin Date: May 2009
Summary:
CHRYSLER/DODGE: TAILGATE SPOILER MODIFICATION. VEHICLES MAY REQUIRE THE ADDITION OF TWO SIDED TAPE TO THE INBOARD EDGE OF THE TAILGATE SPOILER TO PREVENT THE SPOILER FROM TEARING OFF THE TAILGATE WHEN CARGO IS UNLOADED. ( NHTSA ITEM NUMBER - 10030346 )
10. ENGINE AND ENGINE COOLING:ENGINE Bulletin Number: TB-18-016-09
Summary:
DODGE: MIL ILLUMINATION OR STORED DIAGNOSTIC TROUBLE CODE (DTC) FOR P1004 OR 02016 OR 02017. THIS INVOLVES REPLACING THE SHORT RUNNER VALVE (SRV), SRV CONNECTOR, WIRING PIGTAIL, AND ADDING A NEW STUD FOR A TIE STRAP. THE SRV WIRING TAKEO ( NHTSA ITEM NUMBER - 10030706 )
11. ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:MANIFOLD/HEADER/MUFFLER/TAIL PIPE Bulletin Number: TB-18-016-09
Summary:
12. ELECTRICAL SYSTEM:WIRING Bulletin Number: TB-18-016-09
Summary:
13. ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:EMISSION CONTROL Bulletin Number: J-04
Bulletin Date: Mar 2009
Summary:
DODGE: A NON APPLICABLE VEHICLE EMISSION CONTROL INFORMATION (VECI) LABEL WAS INADVERTENTLY INSTALLED. CSC LETTER WAS RECEIVED. ( NHTSA ITEM NUMBER - 10028833 )
14. EQUIPMENT:OTHER:LABELS Bulletin Number: J-04
Summary:
15. TIRES Bulletin Number: SB-22-0001-0
Summary:
CHRYSLER: VEHICLE VIBRATION OR SHAKE AT HIGHWAY SPEED: THE TIRES ARE FLAT SPOTTED DUE TO SHIPPING OR SITTING IN THE LOT FOR AN EXTENDED PERIOD, THE VEHICLE VIBRATION WILL GO AWAY AFTER THE TIRES ARE WARMED UP, (NORMALLY 10 TO 20 MILES OF HI ( NHTSA ITEM NUMBER - 10028944 )
Old 10-28-2010, 08:38 PM
Rogue's Avatar
Rep:22
Default As of 10/28/10 for 1500 4wd w/5.7
08-018-10 JUL 10 Electrical - Trailer L/H Turn Signal Function Inop.
08-014-10 JUN 10 Audio System - REN/REZ Radio Lock Up
19-004-10 MAY 10 Steering - Wandering Condition
08-007-10 APR 10 Instruments - Cluster Economy (ECO) Light Activation
22-001-10 APR 10 Wheels/Tires - Highway Speed Shake Or Vibration
23-006-10 MAR 10 Body - Hood Creaking/Squeaking Sound On Turns/Bumps
08-004-10 MAR 10 Entertainment System - Disabling Front Seat Video Source
Old 10-28-2010, 08:59 PM
Rogue's Avatar
Rep:22
Default My car stats.com for 2009 Ram 1500
---- CAR REPORT VIEWER ----
13 Service Bulletin Reports Now Loaded - Last Bulletin added on: 10/15/2010
Complaints 14
Car Recalls 0
Bulletins 13
Investigations 0
ALL Past
Last 45
QTY COMPONENT GROUP AFFECTED
0 Air Bags, Seats, Seat Belt Reports No Reports in this Group
0 Air Conditioner, Heater, Ventilation Reports No Reports in this Group
0 Brake Reports No Reports in this Group
0 Child Safety Seat Reports No Reports in this Group
3 Electrical System Reports Read Reports in this Group Close
Yes, include on Custom Report SERVICE BULLETIN:CSN-K17 NHTSA ITEM NUMBER:10034072
MFG Bulletin Date: 09/01/2010
Component: ELECTRICAL SYSTEM: SOFTWARE
Bulletin Summary: DODGE: REPROGRAM HVAC CONTROL HEAD AND INSPECT/REPLACE ACTUATORS. THE HVAC MODE DOOR ACTUATOR GEARS ON VEHICLES MAY BREAK AND RESULT IN THE INABILITY TO FULLY CONTROL THE HVAC FUNCTIONS. CSC LETTER WAS RECD. *PE
Date added to datbase: 10/15/2010
Yes, include on Custom Report SERVICE BULLETIN:TB-18-016-09 NHTSA ITEM NUMBER:10030706
MFG Bulletin Date: 05/15/2009
Date added to datbase: 11/13/2009
Yes, include on Custom Report SERVICE BULLETIN:SB-18-003-10 NHTSA ITEM NUMBER:10033690
MFG Bulletin Date: 01/15/2010
Bulletin Summary: DODGE: BULLETIN INVOLVES REPLACING THE SHORT RUNNER VALVE (SRV), SRV CONNECTOR, WIRING PIGTAIL, AND ADDING A NEW STUD FOR A TIE STRAP. *PE
Date added to datbase: 09/10/2010
3 Engine and Engine Cooling System Reports Read Reports in this Group Close
Yes, include on Custom Report SERVICE BULLETIN:J-04 NHTSA ITEM NUMBER:10028833
MFG Bulletin Date: 03/01/2009
Date added to datbase: 06/01/2009
2 Equipment Reports Read Reports in this Group Close
Component: EQUIPMENT:OTHER:OWNERS/SERVICE/OTHER MANUAL
0 Fuel, Exhaust, Emissions Control Reports No Reports in this Group
0 Interior System Reports No Reports in this Group
0 Lighting and Communications System Reports No Reports in this Group
0 Misc. Component Reports No Reports in this Group
0 Power Train Reports No Reports in this Group
1 Steering Reports Read Reports in this Group Close
Yes, include on Custom Report SERVICE BULLETIN:SB-19-004-10 NHTSA ITEM NUMBER:10033731
MFG Bulletin Date: 05/29/2010
Component: STEERING:RACK AND PINION:PINION SHAFT
Bulletin Summary: DODGE: STEERING WANDER. WHILE TRAVELING ON A STRAIGHT STRETCH OF HIGHWAY, CUSTOMER MAY FEEL THE NEED TO PROVIDE STEERING INPUT TO CORRECT A VEHICLE WANDER CONDITION. *PE
Date added to datbase: 09/15/2010
1 Structure Reports Read Reports in this Group Close
Yes, include on Custom Report SERVICE BULLETIN:SB-09-035 NHTSA ITEM NUMBER:10030346
MFG Bulletin Date: 05/29/2009
Date added to datbase: 09/23/2009
1 Suspension, Wheel, Tire Reports Read Reports in this Group Close
Yes, include on Custom Report SERVICE BULLETIN:SB-22-0001-0 NHTSA ITEM NUMBER:10028944
MFG Bulletin Date: 03/07/2009
Component: TIRES
Date added to datbase: 06/08/2009
2 Visual System Reports Read Reports in this Group Close
Yes, include on Custom Report SERVICE BULLETIN:SB-J-06 NHTSA ITEM NUMBER:10032711
MFG Bulletin Date: 10/01/2009
Date added to datbase: 04/30/2010
NOTE: Any and all 2009 Dodge RAM 1500 Technical Service Bulletins (TSB) are an advisory issued by Dodge for use by dealership service departments. Bulletins differ from recalls in that they are not considered safety or emissions issues and they usually apply only when your vehicle is in its warranty period. TSBs usually but not always address a recurring problem. Read more about TSBs and Secret Warranties.
Old 01-09-2011, 10:58 PM
Rogue's Avatar
Rep:22
Default As of January 9, 2011
Old 03-11-2011, 11:10 PM
Rogue's Avatar
Rep:22
Default As of March 11,2011
K23 OCT 10 Campaign - Front Bumper Chrome Corrosion
K17 SEP 10 Campaign - AC Control Programming/Air Door Actuators
K10 AUG 10 Campaign - Seat Cover Perforation
23-022-10 NOV 10 Body - Water Leak Diagnostics Information
23-018-10 OCT 10 Body - Lower Door Hinge Popping Groaning Noises
14-005-10 SEP 10 Body /Fuel- Fuel Filler Housing Pops Out Of Opening
23-015-10 SEP 10 Body - Front Bumper Corrosion
23-009-10 JUL 10 Body - Quad Rear Doors Won't Lock/Unlock
