Old 05-30-2011, 04:48 PM
Rogue's Avatar
Rogue Rogue is offline
Vehicle: 2009 Ram 1500 Crew Cab 4x4
Trim Level: TRX, 25T pkg w 5.7 L
Rep:22
Rogue is on a distinguished road
Send a message via ICQ to Rogue
Default As of May 30, 2011 from AllData
Automotive Recall and Technical Service Bulletin Titles for 2009 Dodge Truck RAM 1500 Truck 4WD V8-5.7L.
TSB Number & Issue Date TSB Title
J12 JUL 09 Recall - HVAC Control Module Programming
J08 JUN 09 Recall - Potential Clutch Pedal Link Separation (Canada)
H46 JUN 09 Recall - Steering Linkage Defects
J08 MAY 09 Recall - Clutch Pedal Linkage Rod Defect
H36 MAY 09 Recall - Drag Link/Steering Damper Bracket Defects
J04 MAR 09 Recall - Incorrect VECI Label Installed At Production
K23 OCT 10 Campaign - Front Bumper Chrome Corrosion
K17 SEP 10 Campaign - AC Control Programming/Air Door Actuators
K10 AUG 10 Campaign - Seat Cover Perforation
J06 OCT 09 Campaign - Windshield Washer Fluid Level Sensor
23-022-10 NOV 10 Body - Water Leak Diagnostics Information
23-018-10 OCT 10 Body - Lower Door Hinge Popping Groaning Noises
14-005-10 SEP 10 Body /Fuel- Fuel Filler Housing Pops Out Of Opening
23-015-10 SEP 10 Body - Front Bumper Corrosion
08-018-10 JUL 10 Electrical - Trailer L/H Turn Signal Function Inop.
23-009-10 JUL 10 Body - Quad Rear Doors Won't Lock/Unlock
08-014-10 JUN 10 Audio System - REN/REZ Radio Lock Up
19-004-10 MAY 10 Steering - Wandering Condition
08-007-10 APR 10 Instruments - Cluster Economy (ECO) Light Activation
22-001-10 APR 10 Wheels/Tires - Highway Speed Shake Or Vibration
23-006-10 MAR 10 Body - Hood Creaking/Squeaking Sound On Turns/Bumps
08-004-10 MAR 10 Entertainment System - Disabling Front Seat Video Source
18-003-10 JAN 10 Engine Controls - MIL ON/DTC P1004/P2016/P2017
24-004-09 NOV 09 A/C - Hissing Noise With A/C ON
08-018-09 NOV 09 Engine Controls - TIPM Update For ECM PROM Update Issues
26-001-09 SEP 09 Maintenance - Fluid Flushing Information
14-001-09A SEP 09 Fuel System - Difficult Fuel Fill/Nozzle Shuts Off
22-002-09 JUL 09 Wheels/Tires - Chrome Clad Wheel Balancing Information
18-019-09 JUL 09 Engine Controls - MIL ON/Multiple DTC's Set
08-10-09 JUN 09 Parking Assist System - False Objects Indicated
18-016-09 MAY 09 Engine Controls - MIL ON/DTC's P1004/P2016/P2017
23-015-09 MAY 09 Body - Door Rubs On Fender When Opening/Closing
23-011-09 APR 09 Interior - Front Seat Clicking/Squeaking/Creaking Noises
08-008-09 APR 09 Wipers/Washers - Washer Solvent Level Sensor Weepage
08-003-09 FEB 09 Audio System - Radio Inop. After Battery Disconnect
18-041-08 DEC 08 Engine Controls - ECM Update For Spark Knock/Vibration
21-022-08 OCT 08 A/T - Converter Shudder On Vehicles With Less Than 4K Mi
21-021-08 SEP 08 A/T - Repair/Replacement Guidelines
Old 05-30-2011, 06:21 PM
Rep:2657
i just had 2 repairs done, both covered by extended warranty
2009 Ram 1500 quad cab 5.7L
this list is just backwards from the date of purchase
cracked exhaust manifold, right side, part number 68045559AB
drive shaft replaced due to grinding noise, when shifting from Park or Neutral going into REVERSE, drive shaft coming apart internally. parts 16300101 & 68034551AB
RRT 10-009 955 Exhaust Manifold Stud Replacement
TSB 08-018-09 DTC is erronous, set conditions are irrational ( MDS Oil Pressure Rationallity )
TSB 18-019-09 Drivability & MDS improvements
both needed flash updates to TIPM & PCM
Thermostat tested & replaced, part 52028898AE
replaced Coolant Temperature Sensor also
RRT 09-020 replaced REAR AXLE VENT HOSE RETAINING CLIP
RRT 09-024 creaking, clicking or squeak sound coming from seat
RRT 09-023 Flash Park Assist Module
RRT 09-035 repair tailgate spoiler or electric throttle control light coming on
RRT 05-019 tailgate spoiler or electric throttle control light coming on
TSB 08-007-10 ECO/FUEL SAVER light not turning on
RECALL K17 reprogram HVAC
RRT 09-095 Drivers Side Molding Replaced
Old 08-20-2011, 07:22 PM
Rogue's Avatar
Rep:22
Default As of 8/20/11 for 2009 Ram 4x4 w 5.7 liter
2009 Dodge Truck RAM 1500 Truck 4WD V8-5.7L Recall and Technical Service Bulletin Titles
23-008-11A FEB 11 Body/Lighting - Puddle Lamp Inop/Tailgate Spoiler Damage
23-007-11 FEB 11 Body - Erratic Box Lock Cylinder Locking/Unlocking
11-002-11 FEB 11 Exhaust System - Ticking Sound In Cold Temperatures
08-001-11A FEB 11 Audio System - Software Enhancements
23-015-10 DEC 10 Body - Front Bumper Is Corroded
Old 09-29-2011, 09:15 AM
OMALLEY808 OMALLEY808 is offline
Vehicle: 2009 Dodge Ram SLT
Color: stone white
Rep:64
OMALLEY808 will become famous soon enough
I have a recall for "front bumper corrosion" on my 09 ram SLT. I had rust forming on the bumper from the steel bolts holding the cover bleeding onto the chrome. Is this what I should be looking for or was the recall for something else?
Old 12-03-2011, 02:26 PM
dwjackson2's Avatar
dwjackson2 dwjackson2 is offline
Vehicle: 2009 Dodge Ram 4x4
Color: Blue
dwjackson2 is on a distinguished road
I thought this was interesting and I’m not sure how many folks are aware of this one so I thought I would share it. Recently my 09 RAM started giving me a check engine light when I give the truck full power. Now as much power as this truck has its very rare that I ever need to or have enough road in front of me to punch it. But in the last month I got the change to open it up a bit. The result was a check engine light. The faults where P1004 – short runner valve control performance, and P2016 – intake manifold runner position sensor circuit low. These issues are addressed in TSB 18-003-10. In short the fix was to take the intake manifold off and replace the short runner valve, the stud and wiring connector. The problem is caused because the wiring harness was cut to short at the factory and there isn’t enough slack to allow for some movement. So when I would punch it the harness would get pulled tight and cause a fault.
Old 12-14-2011, 09:07 PM
Rogue's Avatar
Rep:22
Default As of 12/14/11
Old 02-23-2013, 11:51 PM
Rogue's Avatar
Rep:22
Default Edmunds
Recalls
POWER TRAINRIVELINEIFFERENTIAL UNIT
Vehicle: 2009 Dodge Ram Pickup 1500
Recall Number:
13V038000 Dates Manufactured:
Feb 2008 to Jun 2009 Number of Vehicles Affected:
278222 Date Owners Notified On:
N/A
Defect Description:
Chrysler is recalling certain model year 2009-2012 Ram 1500 trucks manufactured from February 27, 2008, through June 30, 2009, and from December 1, 2009, through October 20, 2011; model year 2009-2011 Dodge Dakota trucks manufactured from February 27, 2007, through June 30, 2009, and from December 1, 2009, through September 30, 2011; model year 2009 Chrysler Aspen trucks manufactured from January 3, 2008, through December 18, 2008; and model year 2009 Dodge Durango trucks manufactured from January 3, 2008, through December 18, 2008. The rear axle pinion nut may loosen due to an undersized pinion spline that can allow relative motion between the nut and companion flange.
Consequence of Defect:
If the rear axle pinion nut loosens, the axle can lock up and cause a loss of vehicle control and/or a vehicle crash with little warning.
Corrective Action:
Chrysler will notify owners, and dealers will install a pinion nut retainer, free of charge. The recall is expected to begin during March 2013. Owners may contact Chrysler at 1-800-247-9753.
Recall Number:
12V474000 Dates Manufactured:
Jul 2009 to Nov 2009 Number of Vehicles Affected:
44300 Date Owners Notified On:
N/A
Defect Description:
Chrysler is recalling certain model year 2009-2010, Ram 1500 and Dodge Dakota trucks, manufactured from July 1, 2009, through November 30, 2009, because a rear axle pinion nut may loosen due to a lack of adhesive.
Corrective Action:
Chrysler will notify owners, and dealers will install a pinion nut retainer, free of charge. The recall is expected to begin in November 2012. Owners may contact Chrysler at 1-800-247-9753.
STEERING:LINKAGES:TIE ROD ASSEMBLY
Recall Number:
10V657000 Dates Manufactured:
Aug 2007 to Sep 2010 Number of Vehicles Affected:
22274 Date Owners Notified On:
N/A
Defect Description:
CHRYSLER IS RECALLING CERTAIN MODEL YEAR 2008-2011 DODGE RAM 4500 AND 5500 VEHICLES. THESE VEHICLES MAY EXPERIENCE A WEAKENING AND FRACTURE OF THE LEFT BALL STUD ON THE TIE ROD RESULTING IN THE POTENTIAL LOSS OF STEERING.
LOSS OF STEERING CONTROL OF THE VEHICLE COULD INCREASE THE RISK OF A CRASH.
Corrective Action:
CHRYSLER WILL NOTIFY OWNERS AND REPLACE THE LEFT OUTER TIE ROD FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN DURING FEBRUARY 2011. OWNERS MAY CONTACT CHRYSLER AT 1-800-853-1403.
SERVICE BRAKES, HYDRAULIC
Recall Number:
10V009000 Dates Manufactured:
Aug 2009 to Dec 2009 Number of Vehicles Affected:
20045 Date Owners Notified On:
Feb 2010
Defect Description:
CHRYSLER IS RECALLING CERTAIN MODEL YEAR 2010 CHRYSLER SEBRING; DODGE AVENGER AND NITRO; JEEP LIBERTY, COMMANDER AND GRAND CHEROKEE; AND MODEL YEAR 2009-2010 DODGE RAM TRUCK. THESE VEHICLES MAY HAVE BEEN BUILT WITH AN IMPROPERLY FORMED OR MISSING BRAKE BOOSTER INPUT ROD RETAINING CLIP.
THIS COULD RESULT IN BRAKE FAILURE WITHOUT WARNING WHICH COULD CAUSE A CRASH.
Corrective Action:
CHRYSLER WILL REPLACE THE BRAKE BOOSTER INPUT ROD RETAINING CLIP FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN DURING FEBRUARY 2010. OWNERS MAY CONTACT CHRYSLER AT 1-800-853-1403.
EQUIPMENT:ELECTRICAL:AIR CONDITIONER
Recall Number:
09V158000 Dates Manufactured:
Apr 2008 to Jan 2009 Number of Vehicles Affected:
36793 Date Owners Notified On:
Aug 2009
Defect Description:
CHRYSLER IS RECALLING 36,793 MY 2009 DODGE RAM LIGHT DUTY PICKUP TRUCKS EQUIPPED WITH MANUAL TEMPERATURE CONTROL (MTC) ONLY. THE SOFTWARE PROGRAMMED INTO THE HEATING VENTILATION AND AIR CONDITIONING MODULE MAY CAUSE THE WINDSHIELD DEFROSTING AND DEFOGGING FUNCTIONS TO BECOME INOPERATIVE.
THIS CAN DECREASE THE DRIVER'S VISIBILITY UNDER CERTAIN DRIVING CONDITIONS AND RESULT IN A CRASH WITHOUT WARNING.
Corrective Action:
DEALERS WILL REPROGRAM THE HVAC MODULE FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN ON OR BEFORE AUGUST 3, 2009. OWNERS MAY CONTACT CHRYSLER AT 1-800-835-1403.
VISIBILITY:WINDSHIELD WIPER/WASHER:MOTOR
Recall Number:
09V084000 Dates Manufactured:
Apr 2008 to Oct 2008 Number of Vehicles Affected:
65896 Date Owners Notified On:
Aug 2009
Defect Description:
CHRYSLER IS RECALLING 65,896 MY 2008-2009 LIGHT AND HEAVY DUTY DODGE RAM PICKUP TRUCKS. THE WINDSHIELD WIPER MODULE MOTOR ASSEMBLY MAY BE SUSCEPTIBLE TO WATER INTRUSION THAT COULD RESULT IN PARTIAL OR COMPLETE LOSS OF WINDSHIELD WIPING CAPABILITY.
WHEN THE WIPER SYSTEM FAILS, THE OPERATOR WILL HAVE REDUCED VISIBILITY WHICH COULD RESULT IN A CRASH.
Corrective Action:
DEALERS WILL REPLACE THE WIPER MODULE ASSEMBLIES WITH VENTED WIPER MOTOR HOUSINGS FREE OF CHARGE. THE SAFETY RECALL BEGAN ON AUGUST 17, 2009. OWNERS MAY CONTACT CHRYSLER AT 1-800-853-1403.
POWER TRAIN:CLUTCH ASSEMBLY:PEDAL/LINKAGE
Recall Number:
09V078000 Dates Manufactured:
Aug 2008 to Jan 2009 Number of Vehicles Affected:
504 Date Owners Notified On:
Jun 2009
Defect Description:
CHRYSLER IS RECALLING 504 MY 2009 DODGE RAM 2500/3500 PICKUP TRUCKS HEAVY DUTY CAB CHASSIS WITH MANUAL TRANSMISSION AND POWER ADJUSTABLE PEDAL PACKAGE. THE CLUTCH PEDAL CONNECTING ROD TO THE CLUTCH MASTER CYLINDER MAY SEPARATE FROM THE MASTER CYLINDER. THIS MAY NOT ALLOW DISENGAGEMENT OF THE CLUTCH WHEN THE PEDAL IS DEPRESSED, WHICH COULD RESULT IN UNINTENDED VEHICLE MOVEMENT.
INCREASED STOPPING DISTANCE AND ENGINE STALLING MAY OCCUR INCREASING THE RISK OF A CRASH.
Corrective Action:
DEALERS WILL REPLACE THE CLUTCH MASTER CYLINDER HYDRAULIC SYSTEM FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN DURING APRIL 2009. OWNERS MAY CONTACT CHRYSLER AT 1-800-853-1403.
Recall Number:
09E009000 Dates Manufactured:
N/A to N/A Number of Vehicles Affected:
1364 Date Owners Notified On:
Aug 2009
Defect Description:
CHRYSLER IS RECALLING 1,364 WINDSHIELD WIPER MODULES, P/N 55077098AJ, SOLD DURING THE 2008 AND 2009 CALENDAR YEAR FOR USE AS AFTERMARKET REPLACEMENT EQUIPMENT ON MY 2002-2009 DODGE RAM PICKUP TRUCKS. THESE WIPER MODULE ASSEMBLIES MAY BE SUSCEPTIBLE TO WATER INTRUSION THAT COULD RESULT IN PARTIAL OR COMPLETE LOSS OF WINDSHIELD WIPER CAPABILITY.
Corrective Action:
DEALERS WILL REPLACE THE WIPER MODULE ASSEMBLIES WITH VENTED WIPER MOTOR HOUSINGS FREE OF CHARGE. THE SAFETY RECALL BEGAN ON AUGUST 28, 2009. OWNERS MAY CONTACT CHRYSLER AT 1-800-853-1403.
Old 10-28-2014, 10:53 AM
rustypipes12 rustypipes12 is offline
Vehicle: 2009 Dodge RamTRX4
Trim Level: TRX4
Color: Blue
rustypipes12 is on a distinguished road
Anything on know knocking noise from dash, then air only going to floor? I filed a compliant with nhtsa,and car complaints.com. seems fairly common problem.
Old 10-28-2014, 05:03 PM
Ramzaq Ramzaq is offline
Vehicle: 2009 Ram CC 4X4
Trim Level: SLT, Big Horn
Color: Black Pearl coat
Rep:233
Ramzaq has a spectacular aura aboutRamzaq has a spectacular aura aboutRamzaq has a spectacular aura about
K-17 recall. It is an actual safety recall already in effect. Check with your dealer or if you are still under warranty it will be covered.
It is the blend door motor causing your problem. It is located below the radio
