98 Ram loading up at idle - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 08-23-2009, 02:43 PM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
Default 98 Ram loading up at idle
My SS/T has done this since I've had it...but, if I let it sit and idle for a couple minutes...or, sometimes, even just sitting at a red light...it'll begin to load up.
It starts with the idle getting choppy, then, it moves on to lowering the RPMs and I hear a loud hissing noise coming from up by the motor.
I have no lights on...and, its an all stock, (Minus true dual and no cat) 5.9L...and it runs perfect (expcet when it does this, it backfires until it blows it all out)
So...anyone else have this problem, or know what it may be?
I thought I read once something about a vac leak on the intake???
Thanks in advance.
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
Old 10-05-2009, 08:41 AM
jchevelle70 jchevelle70 is offline
jchevelle70 is on a distinguished road
I am having the same problem with my '99 Ram. Nobody seems to know how to fix it.
Old 10-05-2009, 09:45 AM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
Thanks in advance.
Us with out SS/T's and other 2nd gen rams have this problem aswell. I was also reading about carbon build up being a cause aswell. I don't think it's anything too serious. Mine will do this when it's cold. It's a tad over 35* this morning, it'll be interesting.
But just to make sure, does it like "click" and the idle will change? and then it'll "click" again and go to normal and so on? That's what mine does, along with the neighbors jeep who's is a 2000, about the same time our rams were made. It has to me a chrysler thing for the time.
Old 10-05-2009, 10:36 AM
With mine there is no clicking. It just seems like it loads up and if I don't rev it a few times it will eventually shut off. Also if I don't allow it to warm up it will run rough for about a 1/4 mile.
Old 10-05-2009, 11:10 AM
SilverFire's Avatar
SilverFire SilverFire is offline
Vehicle: 1989 Holden Astra
Rep:25
SilverFire is on a distinguished road
You might check for a worn/bad/broken vacuum line, probably in/related to the intake system. Also check the IAC. I've had a few people with similar problems when I was working at AutoZone, and when we swapped the IAC and replaced all the old vacuum lines, it seemed to go away.
Old 10-05-2009, 08:32 PM
Rep:210
I think I know what it is...I believe the plenum gasket in the intake is bad, as I can hear a vacuum leak pretty loud when it does it...and, its coming from that area.
Also...mine will load up so bad sometimes at red lights that I have to floor it to make it move, and it'll just kinda chug along, then, all of a sudden, nearly flip you back in the bed when it clears up...lol
Also...Alex, no it doesn't click...doesn't idle rough and go back idling smooth....just idles rough.
And, the PO moved my IAC to the intake pipe (going to the fender)...so...could that have something to do with it?
Also...as weird as it may sound...seems like it does it more with the air on...strange yes.
Old 10-06-2009, 06:18 PM
Where is the IAC and what does it do? I know that it is not the intake gaskets, I just replaced them a month ago. I will get a can of carb. cleaner tonight and start checking for vacuum leaks.
Old 10-07-2009, 10:00 AM
Conner Anderson Conner Anderson is offline
Vehicle: 1998 Dodge Ram 1500 4x4
Trim Level: laramie slt
Color: silver
Conner Anderson is on a distinguished road
i had this problem on my 98 and it was a back pressure problem, since theres no cat on it the engine does have enough back pressure to idle. put either a stock cat on it or some kind of muffler and it should clear up, you can find a stock replacement cat on summit for about 250 bucks
Old 10-07-2009, 05:14 PM
It's not a back pressure problem. My truck does have a cat on it and a muffler and neither are plugged up.
Old 10-22-2009, 07:14 PM
cooter400's Avatar
cooter400 cooter400 is offline
cooter400 is on a distinguished road
hey strange does yours do it all the time or just once in a while
