Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 3.7 Liter V6
Custom Dodge Ram Performance Mods - Engine - 3.7 Liter V6 Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Factory Spec: 3.7-liter V6 engine - 210 horsepower, 235 lb-ft of torque.
Old 08-24-2009, 10:28 AM
aggie aggie is offline
Gender: Not Specified
Vehicle: 2006 Dodge Ram
aggie is on a distinguished road
Default Useless Overdrive Gear
Have stock gears for 3.7L V6 single cab short bed Dodge Ram, and the overdrive gear is just about useless on the highway. You need a level road with absolutely zero wind in order for it to keep a constant speed. Otherwise, it will always lose speed. I end up just turning overdrive off while on the highway. What can I do to fix this? Gear swap? Programming? I have a K&N CAI, Jet chip, and aftermarket 22" chrome wheels w/ low pro tires. If gear swap would do it, which one should I get?
Old 08-24-2009, 10:49 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Maybe go to 3.92 gears with those rims and tires?
Old 08-24-2009, 12:14 PM
Thats what I was thinking, just want to make sure that would alleviate the problem.
Old 08-25-2009, 10:34 AM
I see 3.90 gears all over for 9.25" rear differential (I'm assuming that's what is on mine), are these the right ones? I don't see 3.92...
Old 08-25-2009, 04:27 PM
*bump* ?
Old 09-27-2009, 05:11 PM
J1M's Avatar
J1M J1M is offline
Vehicle: 2008 Dodge Ram 1500
J1M is on a distinguished road
Default perhaps a solution to our problem...
Hi Aggie, I to have the very same problem with my truck. if you have a dodge ram 1500 standard cab short bed w/ a 3.7L then chances are you are running a 3:55 gear ratio. i have done a K&N and a magnaflow exhaust so far but still experiencing the same problems as you. my next move is to up the gears from 3:55 to 3:90 or 3:92. there is really no difference in those two gears, but it does depend who you buy from, from any gear shop you will get a 3:90 if you go direct with dodge u will get 3:92. the difference is cost. from a shop about $250 just for gears from a dodge dealer about $500. plus labor from dodge is about $800 and the labor from an ASE certified shop is about $400. hope this helps!
JIM
Old 01-21-2010, 01:06 AM
casualboy454 casualboy454 is offline
Vehicle: 2006 Dodge Ram 1500
casualboy454 is on a distinguished road
Send a message via Yahoo to casualboy454
I have an '06 1500 reg. cab with the 3.7 and the 6-speed manny, and it's bone stock, actually it's the work special model, so it's ultra stock, lol, and i really have no problem at all flattenin hills in 6th...
Old 01-21-2010, 11:08 AM
grandpaclint grandpaclint is offline
Vehicle: 1996 ram1500 4x4, 5.9 v8
grandpaclint is on a distinguished road
spending $$$$$ to keep your ram running is always a good thing
DODGE RAM=MONEY PIT
Old 01-21-2010, 11:27 AM
Rep:1885
DODGE RAM=MONEY PIT
Of course we all know that you NEVER have to spend money on any other brand of truck out there!
Old 01-21-2010, 11:48 AM
jkulysses jkulysses is offline
Vehicle: 2007 Ram Quad Cab
Trim Level: 2500 4x4 HEMI
Rep:68
jkulysses will become famous soon enough
Ya but what gearing did it come with from the factory?
