Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 08-25-2009, 06:34 AM
JLedoux JLedoux is offline
JLedoux is on a distinguished road
Default Service required message
i have a 07 6.7l cummins with 69,000 miles.overhead console says service required.i know this is pre programmed into computer to come on at a set milage.truck is running fine and my dealer is aweful,will not tell me how much this will cost.any help is appreciated.
Old 08-25-2009, 09:43 AM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3934
I found this to clear the light, maybe it will help?
"Turn the key to the ON position, pump the accelerator 4 times to the floor. Turn the key back off. Service interval dinger should be gone. I did that when my oil change reminder came on at 7500. I'm at a hair over 27k now and it hasn't come back."
I also saw that the emissions code comes on around 67k and that requires CCV replacement and EGR cleaning.
Any one else have any advice?
Old 08-25-2009, 11:03 AM
thanks,that doesn't clear it.ccv replacement,that sounds bad.
Old 08-25-2009, 11:26 AM
Vehicle: Blue
Rep:3934
I don't have a Ram but did some searching on the internet. I didn't want you to go unnoticed! Are there any other dealers you could go to? Or a trusted mechanic?
Old 08-25-2009, 08:23 PM
thanks,my mechanic cannot fix this because it does not cause a code,so no check engine light.And all the other dealers are pretty far away,I am thinking of just ignoring the message,maybe put some electrical tape over console screen.Thanks again for helping.
Old 08-08-2011, 09:32 PM
bitter sweet bitter sweet is offline
Vehicle: 2008 mega cab 4x4 cummings
Trim Level: laramie
bitter sweet is on a distinguished road
Any of u dodge techs know the average cost of replacing the crank case filter, 08 mega cummins.My egr has been replace at about 45k.
Old 08-09-2011, 02:30 AM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Kindly curious about this too. My girlfriends dads 6.7 keeps coming up wit the "service required" message and says it needs dpf maintenance I've cleared the code 4 times now (key to on position pump brakes twice and accelerator twice key off, it comes back 300 miles later).
From what I've read it sounds like crank case filter as well
Old 08-09-2011, 10:17 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Resetting the code does not make the issue go away....neither does electrical tape... It will be less costly if you do the maintenance now, rather than a repair later...
Sean
