Old 08-31-2009, 09:36 AM
panshovel's Avatar
panshovel panshovel is offline
Vehicle: 09 Ram 1500 Crew cab 5.7L Hemi
Trim Level: SLT Sport
Color: Deep water pearl blue
Rep:23
panshovel is on a distinguished road
Default Bug deflector loose
09 Ram 1500 OEM deflector put the little push things in the re drilled holes and installed deflector but screws do not tighten , just turn and deflector sems a bit loose on hood with a bit of forward and back wobble . Any suggestions ? Thanks TIM
Old 08-31-2009, 07:33 PM
SilverFire's Avatar
SilverFire SilverFire is offline
Vehicle: 1989 Holden Astra
Rep:25
SilverFire is on a distinguished road
I would try putting lock washers on.
If I read right, you have push in plugs the screws lock into (not 100% on that)...toss them, get some lock washers and locking nuts, and you'll be good to go.
Old 08-31-2009, 08:26 PM
panshovel's Avatar
Rep:23
thanks for reply , yes push plugs ,then screws into that . No way to get nut on other side. Found some larger push plugs am going to try to whittle them down enough to fit tight and hammer em in . If I can do it the screws WILL tighten up the for sure . Thank again Tim
Old 09-01-2009, 08:59 PM
panshovel's Avatar
Rep:23
get er done , used bigger screws and original push plug things. Still had to slip a small screwdriver in between shield and hoo to keep em from turning but they finally grabed
Old 10-03-2009, 07:45 AM
teppy teppy is offline
teppy is on a distinguished road
just wondering how to attach the bug deflector back? The pieces of tape are still on my car. Got my deflector loose so I detached it.
