Trany problem 99 ram - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 09-01-2009, 01:49 PM
ncfirefighter764 ncfirefighter764 is offline
Vehicle: 1999 Dodge Ram 1500 5.9l V8
Trim Level: 4x4 extended cab SLT
Color: maroon / grey
Rep:15
ncfirefighter764 is on a distinguished road
Default Trany problem 99 ram
I have a ram 1500 5.9l v8 that when I push hard on the gas to pass or something like that the rpms shoot up very high in the red. Other then that it shifts very well. The trans fluid is red and doesn't have a burnt smell or odd smell of any kind. I am not sure about the filters condition or if that is something I can change myself. Has anyone had this problem or any ideas on what the problem could be?
Old 09-01-2009, 03:22 PM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
Holy crap. I've got a 98, same thing happened to me yesterday. I posted a thread aswelll, check out some of the replies.
Old 09-01-2009, 07:07 PM
dirtsurferus dirtsurferus is offline
Vehicle: 1998 Dodge Ram 1500 5.9L
Trim Level: Laramie SLT
Color: Red/silver
dirtsurferus is on a distinguished road
yea i have a 98 and the same thing has been happening to me. but now it not only rev's way up like that it sticks out of first sometimes and also doesn't like to downshift out of overdrive. Stupid overdrive...robs all of the power.
Old 09-05-2009, 12:18 AM
Rep:15
I put some Lucas Tansmission Fix in it a couple days ago and it seemd smoother. But the overdrive still acts the same as it did before no changes there. The truck does it worst when it is in the first 10 minutes of operation. also when it should be shifting between 1st and 2nd gears it goes back and forth real quick like it doesn't know if it should shift yet or not. The truck I think is confused so maybe a miss communication someplace. But it does seem as the longer I drive it and the warmer the trany get the better it does.
Old 09-05-2009, 12:20 AM
I'd do a fluid change, filter change and check signals between the computer and the Transmission Control Module.
Old 09-05-2009, 07:24 PM
Rep:15
is there a hook up point in between the computer and TCM to check the signal?
Old 09-06-2009, 05:58 PM
Rep:15
Well I have an appointment woth Sanford Transmissions tuesday at 0815. They are going to do a diagnostic test on it as see if they can figure out what my problem is. The issues are getting worse when I first start it now and try to move in first gear it seems to slip a little as if I am not going to go anywhere. I really think the trany is on its way out. but wierdy enough the warmer the trany gets the better it operates. I am getting a burnt smell now on the dip stick. The fluid is still red so hopefully its not to bad.
Old 09-06-2009, 06:07 PM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
none of you tow with the overdrive on, do you?
I was told by a guy who was an engineer for chrysler til the late 90s, that said what screws up these transmissions is people towing stuff with the overdrive on.
Supposedly, besides that, they can take some abuse, for a long time.
I'm hoping he's right, since, my ss/t has 140,000 miles and the original tranny, no problems. (knocks wood)
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
Old 09-06-2009, 06:12 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:452
hydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of light
Being 10 years old, it could just be ready for an overhaul. I had a guy that worked for me with a 2004 Silverado that had the same problem at around 100,000 miles. A $1,500 overhaul fixed him right up, of course he still had a Chevy after he spent his money. Good luck. I've got 120,000 miles on my 05 hemi with lots of nitrous suppers. Probably living on borrowed time.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's, Helwig rear sway bar,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 245,000 miles To Hell and back. 14.2/96 mph NEDW
Old 09-07-2009, 12:07 PM
Color: Red/silver
i just replaced the filter and fluid on my 98 and after i did that it would not shift out of first no matter what i did. Today i am changing the governor solenoid and one of the other sensors that i forgot the name of...hopefully that will work or else i am going to have to get it rebuilt. :/
