tonneaucovered.com
Old 09-01-2009, 07:50 PM
moparkid moparkid is offline
moparkid is on a distinguished road
Default Need some help picking my performance chip.
Im interested in getting a performance chip for my truck, but I'm not sure which one I should go with. Im looking for the best upgrade. Anyone know which is the best?
Old 09-01-2009, 09:16 PM
I push the skinny pedal
Rep:3308
the best for the 5.7L HEMI is the Diablosport predator. It's the most mod-able and has great pre-sets for the HEMI. Works best when combined with a CAI and exhaust.
Kurtis
Old 09-01-2009, 11:35 PM
I agree with CdnoilRam , Diablosport is probably the best out there .
Old 09-03-2009, 11:23 PM
Catlin987987 Catlin987987 is offline
Vehicle: 2008 Dodge Ram
Trim Level: SLT 5.7 4x4
Rep:21
Catlin987987 is on a distinguished road
What is there the probelms that I have been hearing about diablo and it wreaking trannies?
2008 Dodge Ram 1500, 5.7 Quad-cab 4x4.
Old 09-04-2009, 12:11 AM
Mostly the problems are due to users who think they know what they are doing when setting shift points at WOT. They are trying to shift as close to, or above, redline.
What they don't realize is that by the time the transmission control module makes the gear change, they are up against the rev limiter and the engine is cutting out...creating multiple, high level torque shocks to the transmission and maxing out line pressures.
The best way to set shift points at WOT with a Predator is to be at least 200 RPM below redline, then test. If you are still hitting the rev limiter, back off in 50 rpm increments. The reason it hits the limiter is that it takes a second or two for the TCM to signal a shift and by then, with the shift point set too close to the rev limit, it's already past redline before it shifts. Ya gotta give it a little room to work.
Old 09-04-2009, 12:40 AM
Rep:3308
ah, info I didn't know. Wisdom there me thinks, hrmmm!
Kurtis
Old 09-04-2009, 05:12 AM
stereojensen stereojensen is offline
stereojensen is on a distinguished road
Default question
can you change the shift firmness with the diablo
Old 09-04-2009, 08:08 AM
dodgeman70592's Avatar
Trim Level: Custom
Rep:1648
Wow, Maddog couldnt have put it better.....Predator can change shift points, not so much firmness like a shift kit
Old 09-16-2009, 08:44 AM
LoveMyHemi LoveMyHemi is offline
LoveMyHemi is on a distinguished road
I have an 03 Hemi, Should I still go with Predator? I hear they don't have the update needed.
Thanks
Old 09-16-2009, 06:14 PM
SanAntoneHemi SanAntoneHemi is offline
Vehicle: 2009 Ram 1500 5.7L Hemi
Trim Level: Lonestar
SanAntoneHemi is on a distinguished road
what does WOT stand for?
do you know what RPM redline is for 09 hemi?
