United Radio
Old 09-01-2009, 10:05 PM
krewshal krewshal is offline
krewshal is on a distinguished road
Default '01 1500 Tranny question, Please Help!
I really hope someone can help me with my tranny issues! I have a '01 1500 4x4 with a 5.2. I don't know the transmission type but it is stock for my model. All of a sudden my truck stopped shifting out of first. I changed the filter and fluid. The filter had no debris in it and the fluid was very dirty but not burt. I also put lucas in it. I can get it to shift into third if I really jam on it and skip second. I took it to a shop and they said second gear was gone and wanted $1500 to rebuild. Then last night all of a sudden my check engine light came on and my truck was shifting perfectly! So second gear is still there because it worked last night. Today my truck is back to not shifting into second. The code is P1757 and also P1762 which have to do with the governer pressure sensor. Could my problem just be that sensor?? If so are they hard to replace? Expensive? Please shed some light on this for me, anybody!
Old 09-02-2009, 12:38 AM
Would recommend going to a reputable rans shop that you can trust . I know their far and few between . If you were here in Md. could recommend you to a great shop . Have sent alot of work to them .
Old 09-03-2009, 08:22 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Make sure that your throttle pressure cable is connected. Mine was left off after a rebuild, caused slip shifting in 1 and 2. 1 and 2 are controlled by the pressure cable, 3 and OD are computer controlled( as explained to me).
Old 09-03-2009, 09:19 PM
boostjunkie1's Avatar
boostjunkie1 boostjunkie1 is offline
Vehicle: 2008 Hemi Ram
Rep:62
boostjunkie1 will become famous soon enough
I would replace the Gov-Press solenoid and the valve body. Flush the tranny and put some AMSOIL ATF in there......... You say that it had some debris though???? Metal? If allot of Metal was in there you need to put all that money into a Performance Tranny for $2,000 and you will never have to worry about your tranny again.- - - Oh and you have the 47re Auto..... 3spd w-o/d
Old 09-04-2009, 12:24 PM
Thank you all for your responces. I will let you know how it works out for me I should be working on it this weekend
Old 03-08-2010, 11:57 AM
Warfield619's Avatar
Warfield619 Warfield619 is offline
Vehicle: 2001 Dodge Ram 1500
Warfield619 is on a distinguished road
If you find the problem please let me know. My 2001 1500 4x2 is doing the samething yours is but I dont have any codes. And seems like every shop u talk to just says rebuild $2k.
Old 12-11-2012, 09:01 PM
Mopar Man23 Mopar Man23 is offline
Trim Level: Four Wheel Drive
Color: Red/Silver
Mopar Man23 is on a distinguished road
Hey y'all I got a when I get into the throttle my truck does fine then all the sudden it feels like its slips in neutral or something and the just falls on its face and the when I let of the throttle it seems fine it only does it when I really get into idk what it is somebody please help me out
governer pressure sensor, p1757, p1762, tranny, transmission
