Old 09-07-2009, 03:01 PM
2001cowboycadillac's Avatar
2001cowboycadillac 2001cowboycadillac is offline
Vehicle: 2001 Dodge Ram 1500
Color: Blue
2001cowboycadillac is on a distinguished road
Exclamation Lug bolts Sheering off
Hi all, i have a 2001 ram 1500 with the 5.9 v8 and within the past month 2 lug bolts on the passanger side front tire sheered off so im running on 3 of 5 till i work on it in the morning, i know i have a bad ball joint but what could cause this? can you change the bolts or does it need a new hub assembly? thanks to anyone who writes back
Old 09-07-2009, 04:32 PM
pwrwgnman's Avatar
pwrwgnman pwrwgnman is offline
Vehicle: 4 trucks
Rep:17
pwrwgnman is on a distinguished road
I would fix the ball joint and replace ALL the studs on the front end, They may have over torqued them if ya got new tires or a rotation? Dunno but for sure change the rest out before ya end up in the woods unintentionally
Old 09-07-2009, 04:55 PM
howln's Avatar
howln howln is offline
Vehicle: 2013 Ram
Trim Level: Sport Quad 4x4
Color: Deep Cherry Red
Rep:15
howln is on a distinguished road
cowboy; I agree, way over-torqued. I always ask the mechs at the tire shop what their torque wrenches are set for, most of them don't know, they just run em until it stops. If the rotors are good, I'd just replace the studs; or may be a good time to update the rotors. You didn't say, did you just have tires installed or rotated? If so, I'd be going back to the shop and have them do the stud replacement.
"Dream Like You'll Live Forever; Live Like You'll Die Tomorrow" James Dean
