2006 Ram aftermarket radio install - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 09-07-2009, 04:12 PM
jerzey111's Avatar
jerzey111 jerzey111 is offline
Vehicle: 2006 Dodge Ram QC
Trim Level: stl
Rep:79
jerzey111 will become famous soon enough
Default 2006 Ram aftermarket radio install
hey everyone,
i'm trying to install an aftermarket radio in my 06 ram, it used to have nav in it. The problem is that the new radio doesnt turn on when i turn the key, it gets power because i can take the cd in and out but i wont turn on. I checked all the wires and everything is fine. Everything works when i connect acc wire to constant so its not radio issue.
Does anyone of you have any idea what could be causing this?? Thank you.
Edit i just found an on crutchfield that my car has no accessory power lead at the receiver and i have to buy an adapter for $130?? wtf??
http://www.crutchfield.com/S-inqpEWH...8265&inst=7453
Im sure some of you guys here changed your radios. Can you shine some light on this??
Thank you
Luke
Old 09-07-2009, 04:42 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
You will need to run another wire from the fuse box to the radio. The stock wiring does not carry enough power to turn the radio on. What happened to your nav unit?
Old 09-07-2009, 05:35 PM
jerzey111's Avatar
Trim Level: stl
Rep:79
i actually just bought it and the guy took the nav out as part of the deal. Well for now i just connected the acc to constant and i take the face off when i leave. Fuse box huh?? Sounds little too complicated for me. Even done it before?? Is it hard??
Thank you for all your help.
Old 09-07-2009, 06:05 PM
chithead's Avatar
Rep:2078
Not hard at all. There is a fuse box under the hood near the battery that makes everything real easy.
Old 09-07-2009, 08:43 PM
bigjeff64's Avatar
bigjeff64 bigjeff64 is offline
Vehicle: 2001 Dodge Ram Quad Cab
Rep:20
bigjeff64 is on a distinguished road
did crutchfield explain what you need that adapter for? The only thing I can think of is it might be cuz u aren't using the nav. Like with some chevy's you could not remove the radio out of the car or it wouldnt start. But running a wire from your fuse box is very simple to do.
Old 09-07-2009, 10:17 PM
jerzey111's Avatar
Trim Level: stl
Rep:79
no they did not, well if you guys say its easy im going to give it a try. Any tips of how i should run the wire??
Old 09-07-2009, 11:30 PM
bigjeff64's Avatar
Rep:20
Have u ever run a amp power wire before? if not no worries. First u need to find a fuse that has a constant power when the truck is running and not when its off. that way you dont have ur radio on draining ur battery while u sleep. next thing is to run the wire to the firewall and i would look for a rubber graument to run the wire into the cab. this is a hole predrilled from the factory that leads existing wires to the interior so u might be able to trace them back to ur fuse box. Once the wire is in the cab then connect it to the harness and thats it. 1 thing i didnt touch on was cleanliness and that all comes down to u. use zip ties in the cab to hide the wire and you can get as custom as u want under the hood however, in my experiences under the hood i would pick up some wire loom and electrical tape. run the wire as far away from the engine as possible and STAY AWAY FROM THE EXHAUST MANIFOLD!!!!! Lastly wrap the wire in wireloom and electrical tape to protect it from the heat and the elements. I have ran several sizes and types of wires and i stand by the wireloom and electrical tape they even make it different clolrs to brighten up under the hood. Hope this helps and good luck.
P.S. Pick up a Hayes manual from the auto parts store for ur truck they have pictures of where the graument holes are and it gives a detailed breakdown of the fuse box
Old 09-08-2009, 02:10 PM
jerzey111's Avatar
Trim Level: stl
Rep:79
thank you, will try
Old 09-14-2009, 06:57 PM
volcom54626's Avatar
volcom54626 volcom54626 is offline
Vehicle: 2006 Dodge ram QC
Color: Brilliant Crystal Black
Rep:17
volcom54626 is on a distinguished road
can also try hooking up to something that is switched inside the cab, such as the cigarette lighter, just tap right into the power of it on the back, much simpler then running a new wire from the batt.
Old 09-15-2009, 12:16 PM
jerzey111's Avatar
Trim Level: stl
Rep:79
thats exactly what i did
thanks
