Old 08-17-2012, 09:38 PM
linsys linsys is offline
Vehicle: 2000 Dodge Ram 1500
linsys is on a distinguished road
Default 2000 Dodge Ram Sub Box
Does anyone have any experience with these:
http://www.halfpricecaraudio.com/Roc...lifier-Kit.htm
I was thinking of getting on for my 2000 Dodge Ram 1500 Quad Cab, I just picked up a head unit from Crutchfield but their custom sub boxes are just too expensive (I already have a sweet system in my Chrysler 300 which really gets more use then my truck, but I still want some bass for my truck).
Old 08-18-2012, 06:44 PM
StoneyWV StoneyWV is offline
Vehicle: 2010 Ram Quad Cab 4X4
Rep:27
StoneyWV is on a distinguished road
Better options out there. Everything sounds great except the amp isn't large enough in my opinion. I would rather see two high-end 8 inch woofers running twice the power each.
.6cuft is a small airspace and gets very hard to compress very quickly. This takes a lot of power to overcome.
Pushing 200wrms to those woofers in a small .6 enclosure isn't going to give you a whole lot of output for the amount of space the box takes up. In other words if you have a good system in another vehicle,I don't think you are going to be happy with the outcome.
I'd rather see a single ten competition style woofer using the entire box at 1.4 cuft and the whole 400 wrms on it. I think the outcome would be the same with less equipment.
2010 QC ST, 5.7L, 4.10 Gear Swap, 5100 Leveling Shocks at 1.7", K&N Drop-in, Pioneer U310BT, 12" Dayton/Net Audio Sub, JL Components, ARC Audio Amps, Magnaflow 14 inch, Granite Alloys sporting 34" BFG T/A KO, HID conversion full blackout.
Old 08-25-2012, 01:29 AM
Do you think this will fit under the back seat:
http://www.bestbuy.com/site/Kicker+-...&skuId=1752075
Looks close?
Old 08-26-2012, 10:03 PM
Rep:27
If you have 10 inches of room under your seat then make a subwoofer box yourself for half the money. Buy a good 12 600wrms woofer from caraudio.com classified section and drop her in there and push the full 600 to it.
Just my opinion. Or you could buy the FOX box and drop a Type R Alpine in there, then find a good used amp online and you would probably be less than 600 for some killer bass. I'm not a fox guy, but to get good(not mind blowing) bass it's hard to beat the price. It's pretty cheap to vacuum mold plastic.
Old 08-27-2012, 12:17 AM
Dodge Boy13's Avatar
Dodge Boy13 Dodge Boy13 is offline
Vehicle: 1998 Dodge Ram 1500
Rep:23
Dodge Boy13 is on a distinguished road
ebay has a couple specifically made for our models for around 100 bucks
My Build Thread!!
http://www.ramforumz.com/showthread.php?t=118514
