2006 Ram aftermarket radio install - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-09-2010, 06:45 PM
THE TALLIT MAN's Avatar
THE TALLIT MAN THE TALLIT MAN is offline
THE TALLIT MAN is on a distinguished road
is there a DIY on how to remove the stock radio and install an aftermarket... A DIY with plenty of pics ?
THE TALLIT MAN
2005 Anthracite Black, 20's, Kenwood 600W w/ 10" Infiniti Kappa Subs
Old 05-11-2012, 01:46 AM
KevinsRam's Avatar
KevinsRam KevinsRam is offline
Vehicle: 2006 Dodge Ram 4x4
Rep:25
KevinsRam is on a distinguished road
Originally Posted by volcom54626 View Post
can also try hooking up to something that is switched inside the cab, such as the cigarette lighter, just tap right into the power of it on the back, much simpler then running a new wire from the batt.
I want to do this also but i dont know where the "ignition" wire goes and where the "battery" wire would go .... and yes i am new to this
Old 05-15-2012, 09:31 PM
bigpercentcountry's Avatar
bigpercentcountry bigpercentcountry is offline
Vehicle: 2008 Dodge ram
Trim Level: SLT Big Horn
bigpercentcountry is on a distinguished road
I would connect the ACC wire from the stereo to the cigarette lighter hot wire. It's switched power and will work, my brother in law hooked his up like this in his 2006. I bought the way overpriced xsvi6502-nav to hook mine up with, and while it works, it's also a pain in the butt. Everytime you unhook the battery you have to take the dash apart and unplug the adapter to reset it. Use the cigarette lighter or find another switched power source, it doesn't need much power to turn it on.
Old 08-27-2012, 07:24 AM
Striker Striker is offline
Vehicle: 2013 RAM 1500
Trim Level: Outdoorsman
Color: Black on Grey
Striker is on a distinguished road
So just to make sure I understand, you use an adapter harness, exclude the separate square plug with three wires on it, and run a switch power supply either from the fuse panel or a cig. lighter or something. Is this correct?
Old 03-16-2016, 05:58 PM
Ysuran Gunman's Avatar
Ysuran Gunman Ysuran Gunman is offline
Vehicle: 2006 Dodge Ram 1500
Color: Blue
Ysuran Gunman is on a distinguished road
Hey guys, I know this is an old thread, but I'm doing this same thing and needing to tap an ignition power source, which I know what write I'm using for that, but from my harness to the new radio, which wire do I use?
Do I connect both red wires (reds from the new radio harness and the adapter to factory harness) then run another from that? Or how exactly do I do it?
This is my first time venturing into electrical wiring so I don't wanna mess my truck up, as simple as this may be
