Burnout Problems - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 09-08-2009, 01:45 PM
tlipps89's Avatar
tlipps89 tlipps89 is offline
Vehicle: 2003 Dodge Ram Daytona
tlipps89 is on a distinguished road
Angry Burnout Problems
Okay dudes, i have a 03 dodge ram 1500, with a 5.9 gas engine in it. Its 4 door, 4 wheel drive, chipped, dual intake, shift kit, but i can not do a burnout for the life of me. i can barely get it to spin tire around a turn unless its wet out, whats going on?? I try to power brake it and it acts like it doesn't have the balls, Its like something is holding it back... Any ideas?? Its Tires are factory so im not trying to spin super swampers or anything it just cant spin them worth crap. Im also getting beat in races by same trucks only with smaller engines like the 5.2 or whatever they put in them.
-Lipps
Old 09-08-2009, 08:41 PM
ph3nom3non03's Avatar
ph3nom3non03 ph3nom3non03 is offline
Vehicle: 2000 Dodge Ram 1500 4x4
Trim Level: SLT LARAMIE
Color: Intense Blue Pearl
ph3nom3non03 is on a distinguished road
open up your exhaust, your c.a.t's are prolly clogged up ... main factor with dodges performance issues with the 5.9's
Old 09-09-2009, 09:27 AM
tlipps89's Avatar
But i have an aftermarket dual exhaust on it, but your right i still have one factory c.a.t. on it so ill have to check that.. Thanks!
-Lipps
Old 09-09-2009, 10:33 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Might try cleaning the throttle body and intake also. Sounds like some of the sensors have buildup around them.
Old 09-09-2009, 01:30 PM
tlipps89's Avatar
Alright thanks ill see what happens.
-Lipps
Old 09-09-2009, 04:32 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:452
hydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of light
Sounds like time for a hemi or CTD upgrade. But seriously, the cat converter can kill you if it gets plugged.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's, Helwig rear sway bar,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 245,000 miles To Hell and back. 14.2/96 mph NEDW
Old 09-09-2009, 06:49 PM
if your able to get to the cat without taking them trying taking the guts out them lol seen many times.... by stick a long piece of pipe that would fit into the cats and just penetrate them and try knocking everything out it will damage them but if this your problem you could try this by saving money instead of spending over a grand on new cats
Old 09-15-2009, 01:32 PM
nwilson1910 nwilson1910 is offline
Vehicle: 2004 Dodge Ram 1500
Color: RED
nwilson1910 is on a distinguished road
+ 1 on the Hemi idea
Old 09-15-2009, 02:01 PM
CHILLZ HEMI's Avatar
CHILLZ HEMI CHILLZ HEMI is offline
Vehicle: 2008 Dodge Ram 5.7L HEMI
Trim Level: Big Horn, Quad Cab
Rep:47
CHILLZ HEMI is on a distinguished road
Send a message via AIM to CHILLZ HEMI
you could straight pipe it, or get a high flow cat(if needed)....
burnouts, race, trouble
