Old 09-08-2009, 11:49 PM
Mattman84's Avatar
Mattman84 Mattman84 is offline
Vehicle: 2003 Dodge Ram 1500
Trim Level: SLT Reg Cab 4X4
Mattman84 is on a distinguished road
Default Intake air temp sensor adjustment?
I own a 2003 dodge ram 4.7, I have heard that there is a way to adjust the IAT sensor and that will give more power is this possible or true and how?
Old 09-09-2009, 06:53 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
I heard you can add a capacitor or resistor or something to truck it into reading different. Checking to see if I can find it...
Old 09-09-2009, 11:12 PM
BigDaddy112 BigDaddy112 is offline
Vehicle: 2003 Ram 1500 4.7L
Trim Level: Lone Star Edition
Rep:22
BigDaddy112 is on a distinguished road
that would be good to know how to do. let me know if yall find anything
Old 09-09-2009, 11:37 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
The some of the cheaper programmers do this to spoof the computer into reading a rich condition, thereby leaning out the injector output. However it does raise exhaust gas temps, potentially leading to engine damage down the road. Tread carefully.
Old 09-10-2009, 08:12 AM
chithead's Avatar
Rep:2078
^^^ Agreed. I am still looking for that article, but the author did stress not to get too crazy with your calculations as it would burn up some other sensors.
Old 09-10-2009, 08:56 PM
johnnyk416's Avatar
johnnyk416 johnnyk416 is offline
johnnyk416 is on a distinguished road
Send a message via MSN to johnnyk416
It's called a power wire get it at airram.com
Old 09-10-2009, 09:15 PM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
The =POWER=WIRE=> Is a PLUG & PLAY mod that will give you 8-10HP with less than 1 minute to install. Advancing the timing for increased HP is an old trick that has been used for many years. With the newer computer controlled vehicles there are no distributors to adjust, so to gain additional timing advance we need to alter the signal from the air temperature sensor for the desired advance. Your PCM uses the Air Temperature sensors to help control timing and Air/Fuel ratio.
Your O2 sensors keep your Air Fuel ratio nailed to 14.75:1 at all throttle positions except Wide Open Throttle (WOT) so the POWER WIRE can NOT cause you to run rich during normal driving because no matter what the AFR will be 14.75:1. For this reason The Power Wire has been reported to add 1-2MPG increase when driven lightly. But at WOT the Power Wire will add approximately 2.5% at WOT. When your at WOT you are more concerned with HP than MPG at that moment in time and while passing an additional 8-10RWHP is exactly what your looking for.
Old 09-10-2009, 10:35 PM
Leadfootluke Leadfootluke is offline
Vehicle: 1998 Dodge Dakota
Rep:276
Leadfootluke is a jewel in the roughLeadfootluke is a jewel in the roughLeadfootluke is a jewel in the rough
Don't do it.
It is not a good idea to fake your engine that much. Get a CAI, locate the IAT towards the end. You will get more airflow and an accurate temperature reading.
I know that isn't enough to persuade you otherwise, but it is no different than an ebay chip that claims 20hp. It just fools the computer and sends false data.
Old 10-01-2009, 11:43 PM
Mattman84's Avatar
thanks fellas much apprecited
