Old 09-10-2009, 08:08 PM
cooter400's Avatar
cooter400 cooter400 is offline
cooter400 is on a distinguished road
Default Trany problems
will a 01 360 half ton trany interchange with a 318
Old 09-10-2009, 08:32 PM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
yes sir. Same bellhousing bolt pattern. I believe you'll have to use the flexplate and all out of the 318 since the 360 is externally balanced, though.
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
Old 09-10-2009, 08:38 PM
cooter400's Avatar
thanks strang does it matter if its not the same year i havent seen the other truck yet but i think the years are close
Old 09-10-2009, 10:38 PM
Rep:210
I'm sure they're all pretty much the same, as long as they're all the same body style, and...I'm not 100% sure, but, I'm sure it would have to be the same as far as 2wd or 4wd, due to the tail being shorter/longer for the transfer case.
Beyond that...I'm pretty sure they're the same.
Hopefully someone else will chime in to back that up
But, other than that, both engines are the same block, basically.
Old 09-10-2009, 10:48 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Tranny and bellhousing should, flywheel might not though. The 360 is balanced different than the 318. Thought I saw a post asking this question earlier...
