Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
ZDOG
Old 09-11-2009, 03:39 PM
FastGreenCat FastGreenCat is offline
Engine: 1999-2001 359ci (5.9L) Cummins ISB 24-valve Diesel I6 230hp 450lb/ft (manual), 215hp 420lb/ft(auto)
FastGreenCat is on a distinguished road
Question Lower EGT's
Anyone know of the quickest, or best way to lower Exhaust Gas Temperatures? I pull a 36 foot 5th Wheel with my 2001 Diesle Ram 2500. I have a Quadzilla Adrenelin installed and a 4" Straight Pipe.
Old 09-11-2009, 07:54 PM
boostjunkie1's Avatar
boostjunkie1 boostjunkie1 is offline
Vehicle: 2008 Hemi Ram
Rep:62
boostjunkie1 will become famous soon enough
If your 2001 is a HO-6 Speed drop a gear and raise the RPM's. If it is a AUTO..... O/D OFF or 2nd Gear while pulling a HUGE hill. RPM's are the best way Stock...... Your box is sending MORE Fuel and probably adjusting the Timing a little. Bigger Injectors and a Bigger Turbo will also help out drastically!!!!
Old 09-11-2009, 09:12 PM
I have a 5 speed, and I expected the EGT's to drop if I dropped a gear, however they do not for long, the temp actually increases. I also have a ford with a 7.3, and when it downshifts, the temp drops.
Any idea as to why it would not with this truck?
I'm wondering if there is just not enough air going in, like you said, maybe a bigger turbo?
