Old 09-14-2009, 11:18 PM
bigrammer's Avatar
bigrammer bigrammer is offline
Vehicle: 2000 Dodge Ram
Color: Blue
Rep:27
bigrammer is on a distinguished road
Default Blown Rearend
So i just got done swapping out my 9.25 rear axle and opened it up and saw about 6 pinion teeth on the internal magnet. FML. So i got a new one put in and runs great. Just wanted to see if anyone has heard of a crush sleeve going out because i have heard it is very rare?
Old 09-15-2009, 12:36 AM
Rep:4072
Glad to hear you got it fixed and running right, but in answer to your question, the way it was explained to me is, yes, it is uncommon for them to "go out," as they are designed to give a little over time whereas a solid sleeve/spacer would not. I was told the only reason they even use them is it saves time during the assembly/machining process. Don't know if that helps, but I'm sure someone else here can chime in on this.
