Dodge Ram Decals
Old 09-15-2009, 08:31 AM
Calicat771's Avatar
Calicat771 Calicat771 is offline
Rep:26
Calicat771 is on a distinguished road
Exclamation Need Tire Advice/Feedback
Bought an '03 1500 earlier this year and it came with 33" ProComp Xterrain tires on it. Unfortunately only 1 of the 4 have good tread on them. Sooo...I'm tire shopping.
I've narrowed it down to two choices. While I'll go off road sometimes for camping trips, this mainly will be a street truck, as it's only 4x2 and I want some tires that have a decent tread warranty. These two have 40,000.
I need some feedback as to what you may recommend or if you have/have had these particular tires, how do/did they hold up or perform?
Pro Comp Extreme All Terrain:
or Mikey Thompson Baja Radial ATZ
Old 09-15-2009, 10:36 AM
CdnoilRAM CdnoilRAM is online now
Rep:3322
A co-worker runs the ProComp X-treme M/Ts and says they're a great all round tire, so the A/Ts with a better highway ride and wear would top them if you need the durability. Just watch for leaving them sitting for too long as they're a softer tire and can spot after a while.
The M/Ts are a very reliable tire and i've always heard good things about them from guys in the oil field here.
Another to consider is the Toyo M-55s or Nitto terra grapplers as they are good all round tires again with good wear and they throw everything but sand. I run the M-55s on my F-350 work truck and they're amazing in all weather conditions inculding the ice/snow/slush we get on oil field roads in northern alberta.
Old 09-15-2009, 04:17 PM
SilverFire's Avatar
SilverFire SilverFire is offline
Vehicle: 1989 Holden Astra
Rep:25
SilverFire is on a distinguished road
There's one to look into, see if it's available in your size, but only Sam's Club carries it.
The tire is by Goodyear, called the ArmorTrac. It's an A/T tire, has either a 50k or 60k warranty.
After speaking to the techs out there, and a person that's had the tires for about 20k miles, I think they're pretty high up there for a 2WD truck. They're highly rated for highway, and do amazing off road as well.
They also have good tread ratings:
Treadwear: 520
Traction: A
Temperature: B
Old 09-16-2009, 11:44 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
I run Kelly Safari Trex and like them alot. I drive mainly on the road and they keep pretty quite for 285s
