Place your Ad Here!
Old 09-15-2009, 04:42 PM
ramjam02 ramjam02 is offline
Vehicle: 2002 Dodge Ram 1500 4WD QC
ramjam02 is on a distinguished road
Default Bearing/hub assy
I'm trying to change out the right front wheel bearing/hub assy on my 02 Ram 1500, 4WD, 5.9L Quad Cab. On the back of the hub there are 3 recessed bolts which I cannot seem to get a socket to fit flush over. It is a very tight space there due to the steering arm (I think) & its big rubber boot. Any ideas? Thanks.
Old 09-15-2009, 06:16 PM
CHILLZ HEMI's Avatar
CHILLZ HEMI CHILLZ HEMI is offline
Vehicle: 2008 Dodge Ram 5.7L HEMI
Trim Level: Big Horn, Quad Cab
Rep:47
CHILLZ HEMI is on a distinguished road
Send a message via AIM to CHILLZ HEMI
what sockets are you using??? Standard or metric??? And what size of the standard or metric have you already tried to match up???
Old 09-15-2009, 09:04 PM
Tried both. I can get a 19mm on crooked but not flush. Don't want to jack up the heads on these bolts. I've tried both regular & deep well sockets but that arm/boot is in the way.
Old 09-15-2009, 09:31 PM
kgmunro kgmunro is offline
Rep:14
kgmunro is on a distinguished road
Raise and support the vehicle.
Remove the wheel and tire assembly.
Remove the brake caliper and rotor (Refer to 5 - BRAKES/HYDRAULIC/MECHANICAL/ROTORS - REMOVAL).
Remove the ABS wheel speed sensor if equipped, (Refer to 5 - BRAKES/ELECTRICAL/FRONT WHEEL SPEED SENSOR - REMOVAL).
Remove the halfshaft nut.
NOTE: Do not strike the knuckle with a hammer to remove the tie rod end or the ball joint. Damage to the steering knuckle will occur.
Remove the tie rod end nut and separate the tie rod from the knuckle using special tool 8677.
Remove the upper ball joint nut and separate the upper ball joint from the knuckle using special tool 8677.
Pull down on the steering knuckle to separate the halfshaft from the hub/bearing.
Remove the three hub/bearing mounting bolts from the steering knuckle (HALFSHAFT / HUB/BEARING).
Slide the hub/bearing out of the steering knuckle (HALFSHAFT / HUB/BEARING).
Remove the brake dust shield.
Old 09-15-2009, 09:32 PM
Rep:14
I work at a Dodge dealership...the above is from the mopar servicemanual on my computer.
Old 09-15-2009, 10:08 PM
Sounds easy . Have done a couple hub/bearings on 3/4 ton 4x4 's and could not get the hub assembly off of the spindle . Slide hammer , heat , nothing would budge it . Took hours of beating on it before it came off .
Old 09-16-2009, 12:22 AM
Thanks kg & blue. I had a feeling I was gonna have to take apart some of this stuff. I'll have to wait a few days when I have some time off to undertake this project. Thanks again!
Old 09-28-2009, 05:58 PM
Okay. I'm working on this thing as we speak. I got the upper ball joint & tie rod end seperated from the knuckle. Got the 3 bolts off that hold the hub to the knuckle. The hub assy of course will not slide out, it appears somewhat rusted & will not budge. Can I just whale on this thing or what? The steering knuckle is only attached by the lower ball joint & I don't want to mess it up.
Old 09-28-2009, 10:15 PM
Have fun . Thats what I had to do . Maybe one of our factory mopar mechanics has a better idea .
Old 09-29-2009, 11:27 AM
Rep:3337
If in doubt use the hammer wrench method...
