Old 09-15-2009, 05:38 PM
texasf texasf is offline
texasf is on a distinguished road
Default Nitto 285/50 R20 tire pressure
We put these tires on my son's 02 1500 Quad-cab: Nitto 285/50 R20s. They are max rated at 50psi. What psi should we be running normally? He carries people, not cargo. We got the back 2 tires in Feb. and they are already showing significant wear after less than 8,000 miles. Hopefully he hasn't been doing burnouts. I will rotate them in the next couple of days reluctantly since then the worn tires will be on the front.
Thanks!
Old 09-15-2009, 06:37 PM
SilverFire's Avatar
SilverFire SilverFire is offline
Vehicle: 1989 Holden Astra
Rep:25
SilverFire is on a distinguished road
What PSI do you have them at currently? Under-inflation can cause a huge amount of wear.
I generally keep my tires at the max rating, or within five pounds, depending on the tire.
Now, the Nitto's I used to run on my VR-4, I always kept at the max rating, they seemed to wear the best then.
Old 09-15-2009, 09:56 PM
I would run 30 -35 psi . Max means when the truck is fully loaded . I run 30 in my rear tires and 35 in my front .
Old 09-16-2009, 06:31 PM
Husker1111's Avatar
Husker1111 Husker1111 is offline
Trim Level: TRX 4
Rep:193
Husker1111 has a spectacular aura aboutHusker1111 has a spectacular aura about
i run 40 in my 295/60r20 nittos
2010 Dodge Ram 1500 white TRX4, 2" leveling kit, Nitto Trail Grapplers 35x12.5R20, Painted stock wheels off 08 Black, 20% tint on front windows, painted to match fender flares and bumpers. University of Tampa
