United Radio
Old 09-16-2009, 08:47 PM
BlownAMC BlownAMC is offline
Vehicle: 2004 Dodge Ram
Color: Stone White
Rep:14
BlownAMC is on a distinguished road
Default HID Questions....
Ok i have 2004 Dodge Ram 1500 Quad cab. I bought a set of Xentec bulbs and ballast for my truck. It didn't not come with a relayed/fused wiring harness so i got one as well.
Well i went to go install the lights on the truck today and i get nothing, all i hear is the relay ticking. When i go to test the power wire coming off the headlight adapter (to tell the ballasts to turn on) the hid's will flicker once and then nothing.
Anybody have any clue?
the harness, relays, and fuses were good, as well as all the connections. I know this because whenever i would test the power wire like i said it the lights would flicker once and that was it. Other than that the relay just ticks.
Anyhelp would be appreciated.
1988 GMC S-15 (12 second chaser.)
2004 Ram 1500 (The S-15 tow pig/DD)
Old 09-16-2009, 10:12 PM
Color: Stone White
Rep:14
ten people looked at this and had nothing to add?
Old 09-16-2009, 11:02 PM
volcom54626's Avatar
volcom54626 volcom54626 is offline
Vehicle: 2006 Dodge ram QC
Color: Brilliant Crystal Black
Rep:17
volcom54626 is on a distinguished road
where did you hook the fuse up to?
Old 09-16-2009, 11:19 PM
Color: Stone White
Rep:14
it is a normal relay harness that has fuses on the two ballast power lines, and a fuse on the relay 12v power line.
Old 09-16-2009, 11:28 PM
Never heard of that manufacturer . Hard to believe both ballasts would be bad . Maybe check with the manufacture and see if they have any recommendations . I'm unable to install HIds on my Cadillac due to the sensitive electrical system in the car . Owners manual stated that after I started reading up on it . Let me know if you don't have any luck and I''ll see what I can come up with . Talk to ya soon . Tom
Old 09-17-2009, 12:06 AM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
I have HIDs on my 04, Had to buy a simple 4 pole double throw relay, ran a fuse to battery grounded the ballast and good to go. Also wire in some resistors to them to stop the lamp out warning. Not sure if this helps but with our electrical systems they are picky
Old 09-17-2009, 12:23 PM
Rep:17
ya maybe ballast or for some reason they are calling for more then 12v.
