Old 09-18-2009, 12:57 PM
ljonesj ljonesj is offline
Vehicle: 2005 Dodge Ram Quad 1500
Rep:14
ljonesj is on a distinguished road
ur overflow bottle is cracked or has a hole in it and when u fill to the cold mark its leaking back down below the the crack or whole
Old 09-18-2009, 01:14 PM
CORUPTWJ's Avatar
CORUPTWJ CORUPTWJ is offline
Vehicle: 2009 Dodge Ram
Trim Level: St
Rep:37
CORUPTWJ is on a distinguished road
I was going to recommend checking this as well. Check that overflow bottle and make sure the leak isn't coming from there.
Old 09-18-2009, 01:22 PM
pwrwgnman's Avatar
pwrwgnman pwrwgnman is offline
Vehicle: 4 trucks
Rep:17
pwrwgnman is on a distinguished road
Originally Posted by Toms Blue Ram 1500 View Post
I am going to assume that you have a 5.2 or 5.9 V8 . See if you can have the cooling system pressure tested . Will show any leaks you have . The thermostat is in the top of the intake manifold , back underneath the a/c compressor . Yes it is a toughy to do . You do have a bypass hose also . It comes out of the front of the intake and goes to the top of the water pump . That is probably the most overlooked hose . Lot of people don't know about it , and after they see it they don't want to know about it anymore . I would recommend if your going to do the thermostat , tear into it far enough and do the bypass hose while your there . Any more questions feel free to ask . Tom
Thats some good advice right there, that lil bypass hose will cause ya to lose your religion lol
Old 09-21-2009, 04:31 PM
mikeahern mikeahern is offline
Vehicle: 2004 DODGE RAM 1500
Color: BLACK
mikeahern is on a distinguished road
Default coolant leak
Had the same problem. Only at night would I get a leak. It turned out to be the assembly that the upper hose connects to . There is only a O ring not a gasket preventing leaks. I had to take a picture to show the dealer where the coolant was comming from. It would never leak up pressure or when it was hot,just after a cool night. After it heated up I would never have a problem during the day... Good Luck Mike 2004 5.7 1500 ram
Old 09-24-2009, 04:33 AM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
After I "burped" the system a few times, the level has evened out 1/4" below the cold fill line and hasnt moved in a week. No leaks either. I think maybe a little air was left in there.
Sure it'll suck, but it'll make you a man
Old 09-24-2009, 05:45 AM
Rep:4072
Tell me about it!!!!! I had that problem with my Jeep, and for as many times as I popped the hood on that thing to check it out before a long trip, didn't notice it had come loose! That made me feel like the biggest idiot, running the heater in the Louisiana summer just to draw enough heat from the block to make it home only to find that darn thing was the culprit!
Old 12-16-2009, 07:10 PM
04SportHemi's Avatar
04SportHemi 04SportHemi is offline
Vehicle: 2011 Dodge Ram
Trim Level: Hemi Sport
Rep:35
04SportHemi is on a distinguished road
Default O-Ring Coolant Leak
Hey mikeahern,
I'm having that exact issue myself on my 04 Ram. How did they fix this? A new o-ring? How much would I expect to pay to have this fixed? Any help is appreciated.
Thanks, 04SportHemi
Old 12-16-2009, 07:26 PM
Rep:1885
This is a very good possibility. The 3.7/4.7 family of engines are notorious for trapping air and it can be a real bear to get out of you don't have a vacuum lift pump.
