Need Help ASAP. Truck Wont Start!!!!!!!! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Interior and Exterior Lighting
Old 09-21-2009, 12:03 AM
bigrammer's Avatar
bigrammer bigrammer is offline
Vehicle: 2000 Dodge Ram
Color: Blue
Rep:27
bigrammer is on a distinguished road
Exclamation Need Help ASAP. Truck Wont Start!!!!!!!!
I am in a bit of pickle as you might say. I was working on putting some ground effects lights on my truck. I did a test once i had wires in place but not cut to length and they turned on fine. I then cut all the wire lengths down and fastened everything back up. After i did this i went to turn the ignition to the acc position and heard a pop and my radio and all of my other accesories including the insrument cluster would not turn on. Along with all of this once i tried to fully start it wouldnt do anything other than bing bong at me for having the door open and the key in the ignition. So i checked all of the fuses only to find that they were all fine.The interior, headlights, brights, instrument lights, under hood light, and horn still work.
The way i have all of my electrical wired up is as followed:
Strobe Lights: "+" wired w/ inline fuse to slot on interior fuse panel "-" To Screw behind the cowling under cupholder.
Ground Effects: "+" wired to the radio fuse on interior fusel panel "-" Screw that has a wire that runs straight from the battery.
Under Seat Neon Lights: "+" wired to the radio fuse on interior fuse panel "-" screw that is near drivers feet.
All things worked when i did the test before everything was cut to length.
All help is greatly appreciated because i need to be able to get to my classes tomorrow but dont have a car to get there.
Old 09-21-2009, 06:46 AM
pwrwgnman's Avatar
pwrwgnman pwrwgnman is offline
Vehicle: 4 trucks
Rep:17
pwrwgnman is on a distinguished road
not sure on your truck but theres 2 places to check fuses and relays one was in the drivers side door jamb and one is under the hood near the battery, also there may be a fusible link under the hood that fried?
Old 09-21-2009, 07:01 AM
bigrammer's Avatar
Color: Blue
Rep:27
i have checked both sets of fuse panels and have found nothing wrong
Old 09-21-2009, 08:15 AM
bigrammer's Avatar
Color: Blue
Rep:27
UPDATE:
Everytime i go to turn the key the lights that light up the power window switches turn of as soon as i go to turn it over.
When the key is in the ignition the power locks will only unlock the passenger side door and will do nothing to the driver. Wont lock or anything. But once the key is out the locks work fine.
Old 09-21-2009, 04:33 PM
How did you check the fuses ? Pull them and look at them one by one . If you did I would recommend you go back and check with a test light or voltmeter across each fuse . I have seen fuses blow and you can't see where there blown . Let me know what you find . Tom
Old 09-21-2009, 11:50 PM
bigrammer's Avatar
Color: Blue
Rep:27
Found the Culprit!!!!!!!!!!!!! Ends up the square ignition fuse under the hood had blown. It was a very minute break in the fuse and it was 1:30 in the morning so i didnt see it. Thank you guys for lending all of the help. This forum has been nothing short of awesome!!!!!!!!!!!
Old 09-22-2009, 04:55 AM
Engine: 2002-2012 226ci (3.7L) Magnum/PowerTech V6 215hp 235lb/ft
Rep:4376
Glad to know you got it fixed!!
Old 09-22-2009, 08:22 AM
bigrammer's Avatar
Color: Blue
Rep:27
Ya me too. Now i just got to figure out what is going on with these ground effects lights.
