Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Recalls and TSB's.
Old 02-23-2014, 10:30 PM
kj981300 kj981300 is offline
Vehicle: 02 Dodge Ram 1500 SLT QC 4.7V8
Color: Crimson Red
kj981300 is on a distinguished road
does anyone know what this code is - P10300? I have looked everywhere and i cant find anything on it! thanks, KJ.
Old 07-13-2014, 09:15 AM
HHOLDENHSD HHOLDENHSD is offline
Vehicle: 2014 dodge ram
Trim Level: LARAMIE LIMITED
Color: RED
HHOLDENHSD is on a distinguished road
These codes do not appear to be correct for a 2014 Ram 1500 5.7 hemi
Old 11-24-2015, 11:19 AM
oldone1942 oldone1942 is offline
Vehicle: Dodge 3500 Dually 4X4 5.9L Cum
oldone1942 is on a distinguished road
Default Nice Job
Thanks for the post. I'm trying to learn how to use the canbus to find some problems in my '06 Ram 3500 5.9L that are driving me crazy, I'm sure this will help in that vane.
Old 11-30-2016, 07:24 PM
gregoryfork's Avatar
gregoryfork gregoryfork is offline
Vehicle: 2016 Ram 1500 Longhorn
Trim Level: Longhorn
Color: Maximum Steel
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
gregoryfork is on a distinguished road
P24b3 on a standard reading ??
Old 11-30-2016, 07:47 PM
Vehicle: '09 Ram 1500/'16 Ram Ecodiesel
Rep:2849
I can not find any reference to that number P24b3, the b is the reason
some code readers display readings that have letters similar to your reading
P2400 EVAP Emission Sys Leak Detection Pump Ctrl Circ/Open
P2401 EVAP Emission Sys Leak Detection Pump Ctrl Circ Low
P2402 EVAP Emission Sys Leak Detection Pump Ctrl Circ Hi
P2403 EVAP Emission Sys Leak Detection Pump Sense Circ/Open
P2404 EVAP Emission Sys Leak Detection Pump Sense Circ Range/Perf
P2405 EVAP Emission Sys Leak Detection Pump Sense Circ Low
P2406 EVAP Emission Sys Leak Detection Pump Sense Circ Hi
P2407 EVAP Emission Sys Leak Detection Pump Sense Circ Interm/Erratic
P2408 Fuel Cap Sens/Switch Circ
P2409 Fuel Cap Sens/Switch Circ Range/Perf
P2410 Fuel Cap Sens/Switch Circ Low
P2411 Fuel Cap Sens/Switch Circ Hi
P2412 Fuel Cap Sens/Switch Circ Interm/Erratic
P2413 Exhaust Gas Recirculation Sys Perf
P2414 O2 Sens Exhaust Sample Error Bank1 Sens1
P2415 O2 Sens Exhaust Sample Error Bank2 Sens1
P2416 O2 Sens Signals Swapped Bank1 Sens2 / Bank1 Sens3
P2417 O2 Sens Signals Swapped Bank2 Sens2 / Bank2 Sens3
P2418 EVAP Emission Sys Switching Valve Ctrl Circ /Open
P2419 EVAP Emission Sys Switching Valve Ctrl Circ Low
P2420 EVAP Emission Sys Switching Valve Ctrl Circ Hi
P2421 EVAP Emission Sys Vent Valve Stuck Open
P2422 EVAP Emission Sys Vent Valve Stuck Closed
P2423 HC Adsorption Catalyst Eff Below Threshold Bank1
P2424 HC Adsorption Catalyst Eff Below Threshold Bank2
P2425 Exhaust Gas Recirculation Cooling Valve Ctrl Circ/Open
P2426 Exhaust Gas Recirculation Cooling Valve Ctrl Circ Low
P2427 Exhaust Gas Recirculation Cooling Valve Ctrl Circ Hi
P2428 Exhaust Gas Temp Too Hi Bank1
P2429 Exhaust Gas Temp Too Hi Bank2
P2430 Sec Air Inj Sys Air Flow/Press Sens Circ Bank1
P2431 Sec Air Inj Sys Air Flow/Press Sens Circ Range/Perf Bank1
P2432 Sec Air Inj Sys Air Flow/Press Sens Circ Low Bank1
P2433 Sec Air Inj Sys Air Flow/Press Sens Circ Hi Bank1
P2434 Sec Air Inj Sys Air Flow/Press Sens Circ Erratic Bank1
P2435 Sec Air Inj Sys Air Flow/Press Sens Circ Bank2
P2436 Sec Air Inj Sys Air Flow/Press Sens Circ Range/Perf Bank2
P2437 Sec Air Inj Sys Air Flow/Press Sens Circ Low Bank2
P2438 Sec Air Inj Sys Air Flow/Press Sens Circ Hi Bank2
P2439 Sec Air Inj Sys Air Flow/Press Sens Circ Erratic Bank2
P2440 Sec Air Inj Sys Switching Valve Stuck Open Bank1
P2441 Sec Air Inj Sys Switching Valve Stuck Closed Bank1
P2442 Sec Air Inj Sys Switching Valve Stuck Open Bank2
P2443 Sec Air Inj Sys Switching Valve Stuck Closed Bank2
P2444 Sec Air Inj Sys Pump Stuck On Bank1
P2445 Sec Air Inj Sys Pump Stuck Off Bank1
P2446 Sec Air Inj Sys Pump Stuck On Bank2
P2447 Sec Air Inj Sys Pump Stuck Off Bank2
Old 11-30-2016, 08:00 PM
Rep:2849
that number does come up as a FORD POWERSTROKE code
Ford Powerstroke: P24B3 Particulate Matter Sensor Heater Control Circuit/Open
Old 12-12-2016, 12:17 PM
Vorlon Vorlon is offline
Vehicle: 2011 Dodge Ram 1500 4x4
Color: gold/brown
Vorlon is on a distinguished road
Just found this list - thanks for putting it together!
