Old 09-25-2009, 03:58 PM
swansteve332 swansteve332 is offline
Gender: Not Specified
swansteve332 is on a distinguished road
Default Alternator problem?
hi i have a 2001 dodge ram 1500 5.2L every now and then my check gauges light chimes on and my battery gauge shoots up to pin it at 18volts and proceeds to overcharge my battery for a few minutes then goes back down but this time it stayed up there for a while so i was wondering is the alternator on the way out i've heard it could also be a voltage regulator but i can't seem to find the on any autostores website so is the regulator built into the alternator? and help would be great thanks.
Old 09-25-2009, 04:13 PM
Yes sir sounds like the internal regulator is gone bad . If you have a reputable rebuilder in your area , pull it off and have them test it. They could fix it or better yet sell you one of their rebuilt units . I personally don't like to buy rebuilt ones from stores . Have had alot of problems with them . But if you have to ! Don't continue to drive it , tough on the rest of the system including the computer and battery .
Old 09-25-2009, 04:22 PM
MRRMX MRRMX is offline
Vehicle: 2007 Ram Quad cab 4x4
Color: grey
Rep:12
MRRMX is on a distinguished road
If its the OEM alternator from 2001, I would change the alternator due to the age. If its say 2 years old the regulator can be changed. Now if its like my Blazer alternator the regulator was like 2/3 the cost of a reman Alt. Do I chance sswapping out a regulator
and hope the thing works and lasts for a year or to....or pay 1/3 more and get a 1 yrs warranty and a new regulator.
Old 09-26-2009, 06:05 AM
ok i replaced the alternator but it's still doing the same thing i read somewhere online that the voltage regulator is located in the ecu anyone know if thats true.
Old 09-26-2009, 06:59 AM
Haven't heard that . Would be a new one on me .
Old 09-27-2009, 07:26 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
if you've got some sort of electrical volt meter put it across the leads of the alternator while your guage is pegged out. This will tell you the true output level of your alternator.
It could be a bad volt guage in your cluster, or it could be a bunch of other things... but this will tell you if you're alternator is putting out too much juice....
Exco
Bill
Old 09-28-2009, 09:47 AM
ok I'll try that when driving last night i noticed when the gauge light comes on and the battery gauge shoots up my all my lights are flickering i went to turn on the high beam and my radio cut out so there seems to be some sort of voltage issue. there's also a low whining noise but it was making that with new old and new alternator so i don't think it would be the alternator bearing.
Old 06-30-2010, 07:30 PM
Murphdog Murphdog is offline
Murphdog is on a distinguished road
Having this same problem did you ever find the fix?
Old 07-01-2010, 08:15 AM
Rep:1909
Of all the likely problems, the alternator is pretty low on the list of suspects. You're more likely to have a problem with the PCM or related charging system inputs.
Old 06-09-2015, 08:46 PM
flekota flekota is offline
Vehicle: 2001 dodge ram v8 magnum
flekota is on a distinguished road
Default Flekota
Yes there is a internal voltage regulator in the PCM you can buy a new one if your having a lot of problem.280 to 1800 dollars. or you can get a external voltage regulator kit for 54 dollars. I have found there are many things that can make the gage spike and light flicker, check all the ground connection between the motor and body find the PCM on the fire wall and clean it. and the ones on the fire wall they all connect at about the same point. So if you find the one on the PCM case clean it and follow it up to the fire wall and clean all the ones there they will get corroded there because of road sprat coming up behind the engine. This was my brother problem and I hope its mine. I see rust on the one at the PCM so I bet it is.
