Old 09-28-2009, 12:37 AM
loudrango's Avatar
loudrango loudrango is offline
Vehicle: 97 Ram,96 Ram,98 rango,01 rang
Trim Level: ram slt -rango r/t
Rep:64
loudrango will become famous soon enough
Default 96 ram dash removal
has anyone with a 94-97 removed the upper dash?i got it loose,but it's still hanging up somewhere.i got all the screws from behind the black bezel,the one on the underside of the dash that goes to a bracket next to the radio recess and from there i don't see anymore?any help is appreciated.
2005 IASCA Stock 3 World Champion
2004 IASCA World Finals 4th place
Old 09-28-2009, 12:43 AM
What are you doing ? Heater core ? Theres screws all over it . Did you drop the column , remove the passenger side airbag , pull the radio , cluster . When I do mine , I remove everything from the dash and then continue from there . It's alot .
Old 09-28-2009, 01:27 AM
loudrango's Avatar
Rep:64
just pulling it to have it smoothed and painted to match the door panels.pulled the radio and cluster.no passenger airbag on mine.you're not kidding it is alot of work!didn't know what i was getting myself into lol!i might just change the heater core while its all apart anyway.its been in there a looooong time.
Old 09-28-2009, 11:24 AM
Our trucks are notorious for bad heater cores and evaporators . If you continue on , I think I would consider doing both while your there . If you do the heater core make sure you use new coolant . I found out thats one reason (I believe) my heater core went bad . I tested the electrolysis level and it was high . Coolant still looked great . After replacing the core and coolant , I retested the electrolysis level and what a difference in readings . Let me know how you make out . Tom
Old 06-05-2010, 10:59 PM
loudrango's Avatar
Rep:64
...it's been awhile,but i'll l will let you know.(got sidetracked with one of my durangos).thanks Tom.
Old 06-05-2010, 11:02 PM
How did you do ? Still working on it ?
Old 06-05-2010, 11:09 PM
loudrango's Avatar
Rep:64
still working on it lol!!right after i posted this i started doing the supercharger install in the kameleon durango,so now i'm back working on the rams.
Old 06-05-2010, 11:11 PM
Cool , good luck with that . Howd the Durango turn out ?
