Exhaust Question - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 > Exhaust
Exhaust 4.7L Exhaust Discussion
Old 09-29-2009, 03:19 PM
Ram2004's Avatar
Ram2004 Ram2004 is offline
Vehicle: Ram 1500 Quad Cab slt
Color: Dark Blue
Ram2004 is on a distinguished road
Default Exhaust Question
I have run two seperate pipe straight back and was wonderin if i would be able to cut the pipes just before the rear axle and put 90 degree angles aiming down on the ends of them with out messing anything up?
Old 09-29-2009, 04:47 PM
bigjeff64's Avatar
bigjeff64 bigjeff64 is offline
Vehicle: 2001 Dodge Ram Quad Cab
Rep:20
bigjeff64 is on a distinguished road
i'll assume that ur gonna put mufflers on if so then i dont see why not
Old 09-29-2009, 05:12 PM
Ram2004's Avatar
Color: Dark Blue
Not enough back pressure with out the mufflers?
Old 09-29-2009, 06:21 PM
I know here in Md. that if it's a pickup truck (and you don't have a cap on it) that you can run and stop the exhaust underneath the bed of the truck . If the truck has a cap on it , you must exit the exhaust from underneath . Reason is that if you have a cap on it , you are capable of trapping carbon monoxide inside of the cap which could kill you or anyone inside the cap . Don't forget to go the newbie section and introduce your self .
Old 09-29-2009, 06:27 PM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
You will need mufflers. Most places around the U.S. require mufflers, it's the law. Not only that, with emissions testing as strict as it is, you will fail for sure.
Once the mufflers are on, you can dump it before the axle.
Old 09-29-2009, 11:03 PM
Ram2004's Avatar
Color: Dark Blue
im in florida i still have the cats in but havent had mufflers for awhile now. Id like to run them under the truck (without killin people inside) because the pipes rub one of my shocks and the welds keep breaking at the last hanger.
Old 09-30-2009, 06:58 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Might look into one of the dual in/ dual out mufflers then put turn downs right before the rear axle. Make sure they definitely dump down below the axle though. I bought my first Ram and it had 12" glasspacks with 18" tips welded right onto the back of them. Problem was it was lowered, and those tips pointed right at the passenger side of the rear axle. That housing would get super hot on the one side...
Old 09-30-2009, 01:07 PM
SilverFire's Avatar
SilverFire SilverFire is offline
Vehicle: 1989 Holden Astra
Rep:25
SilverFire is on a distinguished road
You definitely need mufflers. Florida has noise ordinance laws in regards to vehicle exhausts...though most cops don't enforce them.
You might look into short glasspacks, the 18" like chithead mentioned will go under the bed nice and easy, and a 45 degree turn down maybe two inches before the axle will give you plenty of heat dissipation so you don't mess anything up.
Old 10-01-2009, 01:40 PM
Ram2004's Avatar
Color: Dark Blue
Thanks for yalls advice, One question i have is if i were to run just the 2 pipes and cats alone and cut them off under the bed would there be enough back pressure for the engine and not harm the truck?
Old 10-01-2009, 05:32 PM
chithead's Avatar
Rep:2078
As long as it goes all the way past the bed you should be ok. But it is proven that mufflers will add more HP than just straight pipes...
