Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 09-30-2009, 12:34 PM
BigD BigD is offline
Rep:22
BigD is on a distinguished road
Default 2002 Dodge Ram electrical problems
Hi all,
New poster/member here...
I have a 2002 Dodge Ram 1500 Quad Cab with the 5.9L engine in it. And have some weird elctrical problems...
Some of these are really strange so bae with me, I can easily reproduce one of them at will.
1) brake lights...
a) under medium acceleration from a stop, the brake lights will come on. They stay on till you get up to speed, typically 3-5 seconds...
b) along with the brake lights, occasionally they have stayed on when the vehicle has been parked, I've seen this a couple times, resolution was to open the hood and slam it down.
1a) is the most annoying.
2) Door locks are intermittent when using the lock/unlock button, most doors work except the drivers.
3) Power windows. The drivers controls always work for all windows. the remaining 3 doors (passenger and both rears) are internittent. Most of the time they don't work, but occasionally have.
There is an after market remote starter and keyless entry (this was a strip down Ram that had a Regency package added to it) so there was no factory keyless entry. Keyless entry works the same as the unlock on the doors. And remote start is fine.
Any ideas of where to look for this problem ? any know common trouble spots ?
Thanks for your assistance !
Big Dave !
Old 09-30-2009, 01:41 PM
Raymc7 Raymc7 is offline
Vehicle: 1998 Dodge Ram 1500 Ext. Cab
Color: Black/Silver
Raymc7 is on a distinguished road
Did you have the problems before the Keyless was installed? Who installed the aftermarket keyless? Check all the harness connections where the keyless is wired. Also water may have gotten into the door controls if the windows were left open in the rain. Open all the door controls and check for moisture.
Old 09-30-2009, 03:06 PM
Brake light in the dash or the lights at the back of the truck . Just noticed also , you haven't stopped at the newbie section and introduced yourself . Stop by and get your forum greeting .
Old 10-02-2009, 09:34 AM
Rep:22
Raymc7 - The keyless entry had been installed professioanlly by a company that installs stuff like that. Auto alarm and stereo type installation company. It had been installed about 3 years ago. I had no problems till recently. The window and door lock issues started this year sometime. The brake lights, I cannot say when it started, I noticed it this year, it was a fluke... I was takin off from a stop on a dark country road, looked in my rear-view mirror, and thought it seemed bighter than usual, so when I let up on the gas I noticed the difference. So I experimented and confirmed what I found.
Toms Blue Ram - Sorry, I introduced myself in the newbie section... Also it is the exterior brke lights that come on. no idiot warnings of any kind on the dash.
Old 12-10-2009, 02:25 PM
hwatkins hwatkins is offline
Vehicle: 2003 Dodge Ram 1500. 5.7 L
hwatkins is on a distinguished road
Default 2003 Power Window (and cruise) Problem
Just like BigD:
Power windows. The drivers controls always work for all windows. the remaining 3 doors (passenger and both rears) are intermitant. Most of the time they don't work, but occasionally have.
There are no electrical aftermarket items installed. I am the original owner and the truck has just over 40,000 miles.
Also, on 90 degree plus days, with the cruise control activated, and I start down-hill (pavement), all of a sudden the engine revs higher. I push and release the overdrive button. The engine rpms settles back to a normal range.
The local stealership had no suggestions except to bring it in for diagnosis.
This is my first post so I'm headed to the intro forum.
Thanks in advance for your help.
HKW
Old 12-10-2009, 08:42 PM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
Originally Posted by hwatkins View Post
Just like BigD:
HKW
On my '02 if I'm in cruise and going downhill, if the speed picks up more than 6 or 7 MPH the trans will downshift to help slow the truck. Could that be what you're seeing? Your RPM's will jump up if the trans has shifted.
Old 12-10-2009, 08:49 PM
Resident Technician
Rep:1915
1) Sounds like a sticking or misadjusted stop lamp switch
2) Possibly a weak battery in your FOB and a bad actuator on the drivers door.
3) Possibly bad switches on the other doors. Maybe from contact corrosion from lack of use if you normally open the windows from the drivers switches.
Old 04-07-2010, 12:29 PM
mike223 mike223 is offline
Vehicle: 2003 Ram 1500
Trim Level: 4x4 quad Cab
Color: silver
mike223 is on a distinguished road
had the same issue with the brke lights but the only way I could shut them off was to cross the ground pin and brake pin in the trailer plug connection. I ended up taking it in to the "stealership" as you put it so truly and there was a 4 volt outpu signal from the instrument cluster to the brakes, ended up having to replace the cluster...1200.00 later the problem was fixed.
Hopefully you don't have the same issue.
Mike
Old 09-16-2010, 01:16 PM
Velander's Avatar
Velander Velander is offline
Vehicle: 1974 D200 Voyager Club Cab
Trim Level: Club Cab
Color: Blue
Velander is on a distinguished road
Default Window control problems on 2003 Ram Pickup
I purchased a used 2003 Ram pickup about 10 months ago and only the window controls on the drivers door will control the windows. When I am controlling a window from the drivers door the control on the affected door will stop the window from moving when pressed, but doesn't do anything on it's own.
The controls on one of the doors was working one day, but it isn't working now.
Any idea what could be causing the problem or has anyone else solved a similar problem on their truck?
Old 09-18-2010, 02:26 PM
Resident Technician
Rep:1915
You need a new drivers windows switch
