Extended Cab doors Stuck - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Body & Interior
Old 09-30-2009, 02:06 PM
Raymc7 Raymc7 is offline
Vehicle: 1998 Dodge Ram 1500 Ext. Cab
Color: Black/Silver
Raymc7 is on a distinguished road
Default Extended Cab doors Stuck
98 Ram 1500 and I can't open the rear doors. Ive' taken the panel out, sprayed PB blaster on the mechanism at the base of the door. The latch moves out of the way but the door won't open. The top is clear. The door moves but won't unlatch at the bottom. This happened to one door and then the other in a week. Very frustrated!!!!! By the way....newbie here also. Said Hi in the Newbie area. HELP!
Old 09-30-2009, 02:26 PM
Someone else on here just had the same problem recently . Will try to find out who and either have them get in touch with you or I''ll find out what they did .
Old 09-30-2009, 02:54 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
I have heard of this becoming a very common problem with trucks in colder climates.
Old 09-30-2009, 02:56 PM
Just sent a message to billycanuk . He had the same problem . I asked him to respond to your thread or let me know . Here was his thread and this was the last time he was on line with us . http://www.ramforumz.com/showthread....0909#post80909 . Cross your fingers . Talk to ya soon . Tom
Old 09-30-2009, 03:15 PM
Color: Black/Silver
Thanks Guys. Appreciate all the help I can get. Real pain not being able to get in the back.
Old 10-01-2009, 08:29 PM
frezingbelow frezingbelow is offline
Vehicle: 2001 Dodge Ram 1500
Color: Black/Silver
Rep:135
frezingbelow will become famous soon enoughfrezingbelow will become famous soon enough
I had this problem as well with the ram I just bought, Only thing is I know my drivers side latch is busted, but my passenger side wouldnt open. So I soaked down the latches with pb blaster and let is sit for a few minutes. After that I got in the back of the truck with the seat up and gave it a couple of hip checks while holding the latch...The door didnt stand a chance. The latch basically rusted itself on to the latch.
Now just to fix the drivers door.
Old 05-21-2010, 09:53 AM
foot1455 foot1455 is offline
Vehicle: 2001 Dodge Ram 2500
Color: Forest Green
foot1455 is on a distinguished road
Default Rear Quad Door Stuck Shut
Has anyone found a sure cure for the rear doors becoming stuck at bottom latch?
I have dismantled the door and manually tried to pull up on latch arm ... no luck. Tried the put my weight into it trick ... did not work.
Any suggestions??
Thanks All
Old 05-21-2010, 10:03 AM
Rep:1625
Any suggestions??
Thanks All
I see this is your first post, welcome to the forum! We're glad to have you here! Sorry, I'm not the guy you're for, but this forum is filled with plenty of other members who may be able to help
Old 02-11-2011, 04:15 PM
billycanuk billycanuk is offline
Trim Level: SLT Laramie
billycanuk is on a distinguished road
Hey folks ... I finally did get my rear doors open! Soaked the bottom latches overnight with a good penetrating oil and then placed a wooden block at the base of the door on the inside. While holding open the handle, A good solid whack to the wooden block with a small sledge hammer ... and it opened! It appears that the bottom latches rust pretty good and seize up without much use. Passenger side works like a dream but driver's side latch will have to be replaced as it's too far gone. Hope this helps someone out.
Thanks ... Billy
Old 03-03-2011, 01:22 PM
reytx1 reytx1 is offline
Vehicle: 2001 Dodge Ram 1500 SLT
Trim Level: Laramie SLT
Color: Blue
reytx1 is on a distinguished road
Mine do the same, but it doesnt bug me much.
I just have to apply some pressure and push the door in, than pull the latch. It works everytime
