Extended Cab doors Stuck - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Body & Interior
Old 03-05-2011, 01:02 AM
DeputyNelson's Avatar
DeputyNelson DeputyNelson is offline
Vehicle: 1998 Dodge Ram 1500
Color: Red aka AWESOME!
Rep:86
DeputyNelson will become famous soon enough
Sounds like preventive maintenance is the best fix for this. I'd suggest anyone reading this check their latches just to be safe.
"Blessed are the peacemakers, for they shall be called the children of God" Matthew 5:9
Old 01-25-2012, 11:33 PM
1BigAzzRam 1BigAzzRam is offline
Vehicle: 97 Ram
Color: Green
1BigAzzRam is on a distinguished road
so i know this is an old topic but i havnt seen the solution to my exact problem. i am having the same issue with both rear doors being stuck however i went as far as taking the panel off one door and even unhooking the rod and actually bending and breaking the little U shaped hook that is connected to the rod with the spring,lever, and red clip that actually latches the bottom latch. I cant see how anything else could or is hanging the door up but i still cannot get it open. i have been prying and kicking and the whole nine yards trying to free it. Any other solutions guys? Oh and the top latch i can get free its the bottom that is stuck, i just cant see that much rust being a problem, i can leg press over 400lbs and i cant even budge this door. Thanks for any help guys!
Old 01-29-2012, 02:10 PM
Vehicle: 97 Ram
Color: Green
Does anyone else have an idea for me? Thanks guys!
Old 02-02-2012, 10:21 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Hit them with white lithium greese. Twice a year also keep bottom latch clear of dirt, road salt. When you wash truck wipe door sill dry, wipe under door. Not only will this keep everything working keeps rust monster at bay longer!
Old 04-01-2012, 01:07 PM
Jason68847 Jason68847 is offline
Vehicle: 2001 Dodge Ram 1500 SLT
Jason68847 is on a distinguished road
I just had this exact same problem with my drivers side rear door unlatches from top but not bottom took the paneling off ( 2 Phillips screws in the hand pocket and one torx under inside door handle then pulls right off even with door shut) I found that the rod that connects the latch to the door handle popped off , put it back in and no problems since
Old 04-02-2012, 12:05 PM
bodaciousbabe bodaciousbabe is offline
Vehicle: 1999 Dodge Ram
Trim Level: Chrome
Engine: 1993-1993 360ci (5.9L) Magnum V8 230hp 325lb/ft
bodaciousbabe is on a distinguished road
Default Stuck Door!
I have the same issue, as does my Sister who has the same truck. Just the driver door, the passenger door works great. We applied pressure to the door when it first started happening and it worked for a while but now it doesn't work. I am so frustrated. Can someone please help me?
Old 04-02-2012, 09:35 PM
ramfam's Avatar
Trim Level: Base
Rep:21
I've found that once you get the doors open clean latches real good of dirt and debres expecaly botom latch. Also lube cables that run latches. Lube up every 6 months with white lithium grese there after and wipe rockers and under doors after washing truck.
Old 07-18-2012, 12:31 PM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
Having same issue on my 99 just the drivers side and my handle on the side of the rear door that you would open from the outside sticks out so my drivers door does not close sometimes and when I get out the drivers door opens the rear door since the latch does not shut the rear door anymore (been tinkering with it) ill get it fixed someday
Old 10-12-2016, 08:02 AM
83th3l 83th3l is offline
83th3l is on a distinguished road
Some people may just have to adjust something inside the door.
I wasn't that lucky. My latch was siezed and I needed a ratchet strap, 4x4, a hammer and can do attitude.
I made a video on how I got my 01 Ram 1500 open. It wasn't easy and it's sketchy. But it's opened.
https://youtu.be/W4UvPNAz3tY
