tonneaucovered.com
Old 10-01-2009, 12:56 PM
frezingbelow frezingbelow is offline
Vehicle: 2001 Dodge Ram 1500
Color: Black/Silver
Rep:135
frezingbelow will become famous soon enoughfrezingbelow will become famous soon enough
Default 2001 Ram Code 0455, evap leak
Any chance this is a common problem on these trucks? I had the same problem with my Intrepid, turned out to be the gas cap, Not so lucky on the truck.
Just thought I woud ask for ideas before It goes to the dealership.
Thanks
Old 10-01-2009, 06:46 PM
CHILLZ HEMI's Avatar
CHILLZ HEMI CHILLZ HEMI is offline
Vehicle: 2008 Dodge Ram 5.7L HEMI
Trim Level: Big Horn, Quad Cab
Rep:47
CHILLZ HEMI is on a distinguished road
Send a message via AIM to CHILLZ HEMI
yeah if the gas cap is on properly and tightened, then you may have a leak somewhere...possibley from the fuel tank vapor lines,
Old 10-03-2009, 11:16 AM
DeadDave DeadDave is offline
Vehicle: 2009 Dodge Ram 1500 4x4
Trim Level: SLT - Big Horn
Color: Detonator Yellow
DeadDave is on a distinguished road
My '01 Dakota with the 4.7 had evap line issues every 9 months... codes p0442 and p0455
Either the line at the evap canister near the fuel tank would split, or the lines under the hood that go to the vacuum pump would split. Once was it the hose to the throttle body, never got "lucky" enough that it was just a loose cap.
Old 10-03-2009, 11:48 AM
They can perform a smoke test to pinpoint the leak if there is one present .
Old 10-03-2009, 01:36 PM
Yep, been there and done that myself. It was a cracked evap cannister.
Sometimes, depending on your mileage, the evap cannister may need to be cleaned and recharged with new media. Newer vehicle evap cannisters cannot be serviced and are a maintenance replacement.
Old 10-06-2009, 02:40 PM
Color: Black/Silver
Rep:135
Ended up being the filler neck. Problem solved.
