Old 10-01-2009, 09:25 PM
legosoldier legosoldier is offline
legosoldier is on a distinguished road
Default Just a little help please
I have a 2002 dodge ram 1500 SLT Quadcab 4x4 with a 5.9L V8. it came stock with 17in rims. I just bought a set of 16in rims to put on it. now the problem is that the brake calibers are getting in the way and will not let the wheel rotate. I thought dodge came with 13in rotors so can anyone tell me why i am haveing this problem.
Old 10-01-2009, 10:56 PM
Dan's Avatar
Dan Dan is offline
Vehicle: 2009 Dodge Ram 1500
Color: Inferno Red
Rep:27
Dan is on a distinguished road
you would need to add a bit to the rotor measurement to allow for the caliper to clear the wheel too. That clearance would also be measured against the inner diameter of the wheel. 16 inches is the outer diameter of the wheels that you bought, so the inner diameter will be less than that.
Old 10-02-2009, 09:35 AM
CHILLZ HEMI's Avatar
CHILLZ HEMI CHILLZ HEMI is offline
Vehicle: 2008 Dodge Ram 5.7L HEMI
Trim Level: Big Horn, Quad Cab
Rep:47
CHILLZ HEMI is on a distinguished road
Send a message via AIM to CHILLZ HEMI
whoever you bought the rims from should have asked you for the exact specs of your truck before you bought them...to ensure that they will fit correctly...it may just be that style of rim wont fit the truck, or they gave you the wrong size...
Old 10-02-2009, 10:17 AM
Front calipers or rear calipers or both f&r .
Old 10-02-2009, 11:36 AM
they did have the specs for my truck but it will not fit front or rear. i am wondering if someone had over sized rotors put on.
Old 10-02-2009, 11:48 AM
Rep:47
whoever sold it to you, should have told you that then...I would call them and ask them...If it was a dealership, they def should have let you know that...I would also call where you got the rims from and tell them that they do not fit properly, and tell them why...Maybe the still sent you the wrong rims...
Old 10-02-2009, 11:52 AM
USMCRONIN1's Avatar
USMCRONIN1 USMCRONIN1 is offline
Vehicle: 08 Ram 1500 4x4
Trim Level: Big Horn Edition
Color: Electric Blue Pearlcoat
Rep:100
USMCRONIN1 will become famous soon enoughUSMCRONIN1 will become famous soon enough
sounds like they it is an oversized rotor issue, i used to have that exact truck, except mine had the 20's on it....*sniff* i miss that beast....
Iraqi War Veteran Four Times Over, and I have a concealed carry permit....any questions?
Old 10-02-2009, 02:48 PM
well it needs new rotors so maybe they can help when they change them.
