Old 10-05-2009, 12:39 AM
ViperRacer ViperRacer is offline
Vehicle: 1999 Dodge Ram 1500 5.2
Trim Level: Laramie SLT
Color: Green and silver.
Rep:36
ViperRacer is on a distinguished road
Default Brake Warning Light
My truck has both the ABS and Brake Warning Lights on. Checked the speed sensor in the rear diff and the wiring to it, all's good. Any ideas on what could be causing this? Or do I need codes?
Old 10-05-2009, 05:34 AM
strobee strobee is offline
Vehicle: 2001 Dodge Ram 1500 4x4 5.9
Rep:15
strobee is on a distinguished road
I would say check the abs sensors.
Tommy
Old 10-05-2009, 10:31 AM
dirtsurferus dirtsurferus is offline
Vehicle: 1998 Dodge Ram 1500 5.9L
Color: Red/silver
dirtsurferus is on a distinguished road
same thing is going on in my truck. needs the computer for the gauges and sensors flashed. for that you have to got o the dealer.
Old 10-05-2009, 09:33 PM
Check all fuses first . Check brake fluid level also . Need to get trouble code next , more than likely it's the sensor .
Old 10-06-2009, 11:40 AM
Johnnyhemi Johnnyhemi is offline
Rep:14
Johnnyhemi is on a distinguished road
check the brake fluid level, and i remember someone having a problem with a wiring issue in the steering column
spartan max cam,sharadon valvebody,srt10 d60 w/4.10s,hedman LTs,SCT Hemifevertuned,much more
Old 10-06-2009, 07:31 PM
MikeD MikeD is offline
Vehicle: 2009 Ram 1500 Quad Cab
Color: Stone White
Rep:13
MikeD is on a distinguished road
You didn't mention what year your truck was, but there is a software update for the '09 that among other things addresses this issue.
Old 10-07-2009, 12:37 AM
Rep:14
since he said he checked the sensor in the diff i assume 3rd gen or older because i do believe all the 09 rams come with 4wabs he has the 3 channel if he has the sensor in the diff
Old 10-07-2009, 01:55 AM
Rep:36
My bad, it's a 99 with the 318.
