Old 10-04-2009, 08:08 AM
95 1500 4x4's Avatar
95 1500 4x4 95 1500 4x4 is offline
Vehicle: 95 Dodge Ram 1500 4x4
Trim Level: Base
Rep:40
95 1500 4x4 is on a distinguished road
Default Front axle not engaging
I recently bought a 95 Ram 4x4 and the front axle doesn't engage, when I shift into 4wd the front driveshaft engages but I guess the hubs are failing to engage.
It does not have manual hubs, is there a fix for this problem?
I tried searching, but came up empty, I'm hoping someone more knowledgeable has seen this problem before or knows how to fix it or bypass it.
Thanks for all your help.
Brian.
Old 10-04-2009, 10:51 AM
You are definitely sure that the transfer case is engaging and the front driveshaft is spinning ? If yes , on the right side of the front axle is a round vacuum pot . Make sure the vacuum line harness is plugged into it . Alot of time the harness just falls off . That vacuum pot pulls a slider in to engage the front axle . It gets it's vacuum signal from a vacuum switch that is located on top of the transfer case . You can check and make sure that switch on top of the transfer case has got it's vacuum harness plugged in also . While doing this kinda eyeball the condition of the plastic vacuum lines . If you find a broken line that will need to be fixed . That could be your problem . Lets stop here , let me know how you make out . Don't forget to stop by the newbie section and introduce yourself and get your official welcoming . Talk to ya soon . Tom
Old 10-04-2009, 01:37 PM
Trim Level: Base
Rep:40
Yeah, I'm sure the transfer case is engaging and the driveshaft is spinning.
I had a friend look under it to make sure.
I sort of looked at that canister yesterday and figured it was sme kinda vacuum hub deal, I don't know much about this rig other than it looks cool and if I can figure out the hub situation it will be really cool.
I'm gonna go crawl around under it and see what I can come up with and report back.
Thanks for the help, I'm really at disadvantage with this truck, Before this Dodge I was die hard Ford fanatic, but one ride in this rig changed all that.
Oh and I did an intro thread, in fact you replied there too, thanks.
Old 10-04-2009, 01:51 PM
Trim Level: Base
Rep:40
You are the man Mr Tom!!!
Climbed under the beast and noticed one of the 2 vacuum lines had broken, went to my shed and found some lines I had saved and now I have 4WD again.
I owe you one buddy, thanks
Brian.
Old 10-04-2009, 01:53 PM
Glad I could help .
Old 10-04-2009, 01:58 PM
Way to go, Tom and welcome to the forum, 95 1500 4X4
