Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 10-19-2009, 09:10 AM
Fast Willy's Avatar
Fast Willy Fast Willy is offline
Vehicle: 2008 Dodge Ram QC
Rep:31
Fast Willy is on a distinguished road
Send a message via AIM to Fast Willy
Default Tire pressure sensor
Well the tire pressure light just came on in my 08. I checked and everything seems to be fine with them. We did just get blast of cold air. Do you think this would cause the light to go off. Or any recommendations would be appreciated before I have to take it to the dealer.
Thanks, Bill
BTW the tires are filled with nitrogen and still the stock tires from the factory are on the truck.
Old 10-19-2009, 12:57 PM
CORUPTWJ's Avatar
CORUPTWJ CORUPTWJ is offline
Vehicle: 2009 Dodge Ram
Trim Level: St
Rep:37
CORUPTWJ is on a distinguished road
If you checked them and they have the right amount of pressure, then yeah, it was probably just the cold. The light will probably go off once you drive around a bit to warm up the air in the tires.
Old 10-19-2009, 03:49 PM
CHILLZ HEMI's Avatar
CHILLZ HEMI CHILLZ HEMI is offline
Vehicle: 2008 Dodge Ram 5.7L HEMI
Trim Level: Big Horn, Quad Cab
Rep:47
CHILLZ HEMI is on a distinguished road
Send a message via AIM to CHILLZ HEMI
No, the cold should not have any type of affect on the TPMS system, is does not measure the temp of air inside the tire...It measures the psi inside the tire...Your light is either caused by the tire pressure itself being over or under inflated, or one of your sensors are malfunctioning(in this case will blink)...however, the cold temp does have an affect on your tires PSI which will drop from 1-3 psi approximately...
