Lowerin my dodge - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-07-2009, 07:24 PM
Rep:3347
But some of us have aspirations of smoking all 4 tires on a lowered truck...or it could just be me.
I'd recommend a 2/4 drop to level it out too if you can find a kit. I checked out groundforce and all they have for that year is rear shackles
http://www.groundforce.com/vehicle.a...Dodge&make=Ram 1500
You could try a shop that specializes in drops and see if they can come up with a custom set up, but it's be expensive. Plus they'd probably try and sell you on laying rocker or frame...and that's just WAY too low for a 4x4.
Old 10-07-2009, 08:09 PM
Johnnyhemi Johnnyhemi is offline
Rep:14
Johnnyhemi is on a distinguished road
McGaughys makes 4wd drop kits if you go to their website
spartan max cam,sharadon valvebody,srt10 d60 w/4.10s,hedman LTs,SCT Hemifevertuned,much more
Old 10-07-2009, 10:52 PM
Rep:3347
Sadly, McGaughty's doesn't make a kit for the 4WD. I say sadly cuz they're a great kit, but everything they make for Dodge's is for 2WDs and nothing for older than '02.
http://www.mcgaughys.com/air%20dodge_chevy.html
Looked around some more, and Belltech's is only rear shackles, but I did find DJMs kit, but it doesn't specify a drive type, you'd have t contact them.
http://www.belltech-sport-trucks.com/productfinder/
http://www.djmsuspension.com/applica...m1500Parts.htm
Old 10-08-2009, 10:52 AM
bigjeff64's Avatar
bigjeff64 bigjeff64 is offline
Vehicle: 2001 Dodge Ram Quad Cab
Rep:20
bigjeff64 is on a distinguished road
we just lowered a 4 wheel drive f150 and we did a 2/4. I spoke to DJM suspension and they said that the lowering is in the torsion keys for the front. Torsion keys will not stress the front axles and if u have the right tools to decompress the springs then its a piece of cake. The rear is the easiest and cheapest. DJM said that if u could either buy a flip kit or use the stock parts if u can get teh old ubolts to fit. That right there is a lil under 4". The flip kit u buy from them is longer u bolts and a c notch to the frame for 160 so do the math!! Hope that helps
Old 10-08-2009, 11:41 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Does the flip kit from them just bolt on? I am curious about this...
Old 10-08-2009, 09:42 PM
bigjeff64's Avatar
Rep:20
All the flip kit consist of is like i said bigger u bolts and new bump stops. The new ubolts are the same type of bolts that r currently there just longer to accomodate any difference on length. Depending on how low u go u may need to cut a c-notch in the frame. the company gives u bolt on notches so u dont have to weld flat stock to the cut box frame the notches are bolt ons but if the truck is high enough u should be able to flip it with just what u have stock. All ur doin is putting the axle above the leaf spring
Old 10-14-2009, 03:30 PM
RedneckDodge's Avatar
RedneckDodge RedneckDodge is offline
Vehicle: 1994 Dodge ram 1500
Trim Level: Magnum 4x4
Color: Red with silver and burgandy stripes
Rep:15
RedneckDodge is on a distinguished road
wow, this is interestin i didn't know u could do that. Could anyone do it or would i have 2 take my truck 2 a shop.
Old 10-14-2009, 03:45 PM
bigjeff64's Avatar
Rep:20
Anyone can do it with the correct equipment and a couple extra sets of hands. I know a couple shops that will charge 85 an hour labor and tell u its a 2 day job. We dropped the back in about 2 hrs. Air compressers are ur best friend in this industry!!!!
Old 10-20-2009, 07:41 PM
Rep:15
thanks everyone, this is really helpin me out.
