Old 10-07-2009, 09:47 PM
dirtsurferus dirtsurferus is offline
Vehicle: 1998 Dodge Ram 1500 5.9L
Trim Level: Laramie SLT
Color: Red/silver
dirtsurferus is on a distinguished road
Default Tranny problem solved? (Warning)
I just got my truck back from the shop where the tranny was being rebuilt. I noticed that a lot of other people were having the same exact problems as me. When they went to do the coolant flush the one way valve inside the radiator coolant hose was coroded shut. They believe that is the reason that the tranny went so badly all at once, and said that the overheating explained all of my problems. I was just wanting to warn anyone with the 46RE or 47RE transmission that if you are experiencing any problems like that and have a couple hours free time, you might want to drain the coolant and check the one way check valve i believe they called it that is inside there to make sure that it is opening correctly.
Old 10-07-2009, 11:24 PM
If it's what I think , it's in the trans cooler line , by the radiator. It's a spring loaded check valve . I took that section of hose off from the trans line and removed that valve and spring .
Old 10-07-2009, 11:31 PM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
whew, nothing yet! Thanks for letting us know!
Old 10-08-2009, 01:35 AM
supermopar77 supermopar77 is offline
supermopar77 is on a distinguished road
well i had a dealer rebuild my trans 5 times in 3 weeks on my truck ..they finally bought a remanufactured on on the 5th time and made me by a new radiator for they did not flush it very well and it kept washing the junk into new transmission...i estimated they spent about 10,000$ and ther werenot very happy about it....
Old 10-10-2009, 12:34 AM
Wow thats great they did what they did and made it good .
Old 08-15-2011, 08:49 PM
siristin274's Avatar
siristin274 siristin274 is offline
Vehicle: 1999 Dodge Ram
Trim Level: Standard
Color: Green
siristin274 is on a distinguished road
Default trans check valve
Does anyone have a diagram as to where the trans check valve is? Also pics would be great thanks...
Old 08-31-2011, 10:56 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Horrible way to address drainback issues. Remove it and put a proper valvebody kit in. It'll solve the drainback issues and extend the life of the transmission.
5.9l, transmission failure
