Old 10-08-2009, 09:21 PM
thermaltech thermaltech is offline
thermaltech is on a distinguished road
Default Wheel Bearing Replacement
05, 1500 5.7 Laramie with 31000 miles. I notice a recent low frequency noise from the drive side front wheel, I actually feel it in the padels also. Recently had in the garage for inspection. Had them analyze front noise, results is bad wheel bearings, mainly left side. Not covered under warranty. 1k to replace both sides. Is it common for these to go bad with very low miles & How hard is to replace front wheel hubs?
Old 10-08-2009, 11:58 PM
I push the skinny pedal
Rep:3277
It's not common, but there's several reasons they could fail, from shocking the bearing to a seal going and it running dry. As for the hubs I wish I could help you, there's a reason that I keep several mechanic friends who will work for beer. My old Dakota toasted a bearing and it was about a $500 fix for the driverside bearing and hub and it was in for a few hours.
Kurtis
Old 10-09-2009, 09:51 AM
CHILLZ HEMI's Avatar
CHILLZ HEMI CHILLZ HEMI is offline
Vehicle: 2008 Dodge Ram 5.7L HEMI
Trim Level: Big Horn, Quad Cab
Rep:47
CHILLZ HEMI is on a distinguished road
Send a message via AIM to CHILLZ HEMI
to replace a hub bearing could be very difficult if you do not have access to air tools....If you do have access to air tools, its not too bad....
Old 10-09-2009, 10:36 AM
Thanks for the rplies>>>> My next question, Where is the best place to puchase & band name specfic of choice?
Old 10-10-2009, 12:01 AM
Might want to check out Rock Auto . They have excellent prices .
Old 03-08-2010, 10:04 AM
Badass02Ram's Avatar
Badass02Ram Badass02Ram is offline
Vehicle: 2002 Ram Q/C 4.7
Trim Level: ST Sport
Color: Radiant Fire Red/ Murder in progress
Rep:28
Badass02Ram is on a distinguished road
I know this is an old post but for the future refrence of others. I did the bearing on an 04 passenger side and it only took me about 20 min from start to finish. just lift it up take the brakes off and there are 3bolts on the back side to remove it. the bearings are a sealed unit that runs around 100bucks or so and there is 1 plug in for the abs stuff. it was a very easy task to acomplish. and 1K holy **** I am in the wrong business.
Old 03-08-2010, 10:15 AM
Kens04's Avatar
Kens04 Kens04 is offline
Vehicle: 2004 Ram QC 4x4 HEMI
Trim Level: SLT OFF ROAD
Rep:48
Kens04 is on a distinguished road
Exactly, not a hard job. Rotors and bolts could be on there pretty good but thats about it. There are youtube videos of how to do it, I mean they dont tell you how to use a wrench and may not be your make and model but it will give the jist. Buy the part watch some videos and buy a haynes or chilton manual and your good to go.
Old 03-08-2010, 10:35 AM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
my barrings need to be replaced and they said also the wheel hubs to but the dealer is covering all of it
Old 03-09-2010, 01:49 AM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
$1,000 to replace the wheel bearings? Correct me if I am wrong but are these not sealed units, so you can not repack the bearings? Hell, I can see the part running up to $250 or more if you have ABS but less than 30 minutes to replace it. Damn!
