Old 11-28-2009, 03:10 AM
cpelton cpelton is offline
Rep:21
cpelton is on a distinguished road
It will not work, ive looked into this
Old 01-24-2010, 02:12 PM
Cormacs's Avatar
Cormacs Cormacs is offline
Trim Level: Crew Sport
Rep:14
Cormacs is on a distinguished road
I will tell you in about a week if it works. I have ordered the parts but the only problem is they are on back order. I am a mechanic at a dodge dealership and my parts guy said he wouldn't have an issue returning them if it didn't work. I looked under my dash and both connectors are there and waiting to be plugged into it. The only problem I can foresee is the trailer brake controller obviously communicates over the bus since it uses inputs such as ESP from the ABS module and also has outputs to the cluster. What I have experienced in the past when I have done something like this is the network doesn't like it when you just add modules since that module is not in the build. So what I'm gonna do is plug it in and see if the network will just adopt the new module and start useing it. But if that doesn't work I'm gonna call me dealer service rep and pleed with him to add the trailer brake control module sales code to the build. I will keep you informed when the parts come in. The module is cheap it is only like $120 plus like $15 for the trim panel. If it works that is cheap for an inertia style brake controller. Plus if it works properly it uses ESP events to dictate the power to send to the trailer.
Old 01-25-2010, 03:15 AM
My ss got a ls's Avatar
My ss got a ls My ss got a ls is offline
Vehicle: 2010
Trim Level: laramie
My ss got a ls is on a distinguished road
Originally Posted by iRockCrawler View Post
Information on the TBC is also displayed on the EVIC... Not sure if this is available on the 1500's but it is on the 2500 and up..
Yes it is available for the 1500 i ave mine on order now fully loaded and they up graded the towing and payload on the 2010 also so if my 08 1500 hemi ram has no problem towing my quad on the back and inclose at the same time i will be happy
If you cant dodge it ram it
Old 01-25-2010, 04:50 AM
MightyBlueRam's Avatar
MightyBlueRam MightyBlueRam is offline
Vehicle: 2014 Ram 1500 EcoDiezl Laramie
Trim Level: Laramie 4x2
Color: Blue Streak Pearl Coat
Rep:432
MightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really nice
Could you provide the part numbers once you verify that it works that way if anyone else is interested, then they can order with what you used?
Old 01-25-2010, 07:23 AM
Cormacs's Avatar
Rep:14
I sure can. The brake controller is one pat number but the bezel has two different ones. Obviously depending on the colour of the interior. If it works I will bring part numbers, if it doesn't I will inform.
Old 01-25-2010, 10:16 AM
Cormacs's Avatar
Rep:14
Well I just got a call from Chrysler Technical Assistance. They said it is not possible to add the brake controller into the build. I havn't given up yet, I'm going to try and plug it in anyway and see if it will work independantly of the truck's systems.
Old 01-28-2010, 11:55 AM
Cormacs's Avatar
Rep:14
Well, I just installed it today. It works just fine. I hooked it up to my trailer and the lights all light up and you can set the intensity. If you want to do it yourself the part numbers are 56029431AE for the controller itself and 1EB13XDVAA for the trim piece. The trim piece part number is for the dark slate interior. I works great. I will warn you though, the TIPM (Totally Integrated Power Module) sets a trouble code for "Additional Can "C" Bus detected" so it could send a technician in the wrong direction if you actually had a bus problem.
Old 01-28-2010, 11:58 AM
Rep:432
Cool! Good to hear you got it to work. I think this will help out others who might want to get a trailer brake controller. Post a pic when you get a change before the pic ho's start the onslaught..... including me. But i'll give you a chance.
Old 01-28-2010, 01:23 PM
Cormacs's Avatar
Rep:14
It'll have to wait till next week. I'm leaving for toronto tomorrow and I don't think I will have time between now and then. I'm at work and I don't have my camera.
Old 01-28-2010, 09:22 PM
Yotaman96 Yotaman96 is offline
Yotaman96 is on a distinguished road
Does the trouble code actually set off a light? Does the info show on the display screen like stock? Any way to get rid of the trouble code?
2010 Ram 1500 Crew Cab 4x4 Sport
