Old 01-29-2010, 07:02 AM
Cormacs's Avatar
Cormacs Cormacs is offline
Trim Level: Crew Sport
Rep:14
Cormacs is on a distinguished road
No the trouble code is only in the computer, It doesn't trun any lights on. It doesn't show anything on the screen since the truck doesn't know it's there and tech line refused to help me. But the brake controller works great, it talks on the bus to turn on the back lights when the headlamps come on. The display lights up as soon as a trailer is connected and the warns you when it disconnects with a large !. I really like it, I will be sure to get pictures of it with and without a trailer connected.
Old 02-10-2010, 04:03 PM
Yotaman96 Yotaman96 is offline
Yotaman96 is on a distinguished road
Just got my factory trailer brake controller today. Did yours come with any wiring, or are the factory harnesses long enough to reach? Thanks.
2010 Ram 1500 Crew Cab 4x4 Sport
Old 02-10-2010, 06:28 PM
topgun's Avatar
topgun topgun is offline
Vehicle: 2012 Ram 2500 CC 4X4
Trim Level: Outdoorsman
Rep:71
topgun will become famous soon enough
You guys have it real easy with the 2010's. You don't need anything other than the bezel and 3 screws. Plug it right in. You can't mix the plugs as they are 2 different sizes.
Undercover SE, Corsa Cat Back, Amp Powersteps, Amp Bedstep, Bedrug, Mopar Tailgate Lock, Mopar Fold Flat Floor, Mopar Flat Rubber Splash Guards, Cooper AT3 285/70/R17's, S&B Intake, Moroso Catch Can
Old 02-11-2010, 06:48 AM
Cormacs's Avatar
Rep:14
The two plugs are taped up with the harness on the left side behind the dash. There is enough harness to reach the module.
Old 02-16-2010, 04:18 PM
jdolotina jdolotina is offline
Vehicle: 2013 Ram Laramie Longhorn Crew
Trim Level: Laramie Longhorn
Color: Brown
jdolotina is on a distinguished road
If you have a 2010, can you see the adjustments from the gain in the EVIC? If so, that makes it even more convincing to buy one.
Old 02-16-2010, 06:51 PM
topgun's Avatar
Rep:71
Not in the EVIC but on the controller display.
Old 02-16-2010, 06:53 PM
Cormacs's Avatar
Rep:14
No, the controller has it's own screen. I love it simply because it looks good hidden up under the dash. Plus it works with the hill start assist.
Old 02-16-2010, 07:31 PM
topgun's Avatar
Rep:71
Never thought of that. So you can see the brakes continue to be applied when on a hill and you take your foot off the brake? That would mean it is indeed receiving info from the truck's systems.
I've got everything ready to install in my 09. Got the 2 harnesses made up and connected to the controller. Just need it to stop snowing so I can plug it into the truck.
Old 02-16-2010, 11:30 PM
StuartV's Avatar
StuartV StuartV is offline
StuartV is on a distinguished road
Any brake controller *ought* to work with the hill start assist. All that is doing is activating the truck's brakes. Which ought to activate the trailer brake controller, no matter which controller you have.
Old 02-17-2010, 01:02 AM
Color: Brown
I am confused, what actually is supposed to show up in the EVIC with the controller. Considering your truck comes stock with one.
Thanks,
Josh D.
