Old 02-17-2010, 06:43 AM
Cormacs's Avatar
Cormacs Cormacs is offline
Trim Level: Crew Sport
Rep:14
Cormacs is on a distinguished road
no controller will work with the hill start assist. The truck holds the brakes by useing the ABS solonoids. The only way a standard brake controller apply's trailer brakes is by having an input from the brake lights since that's what it is wired to. The brake lights do not stay on when hill start assist is active.
Old 02-18-2010, 01:51 PM
CosmicVagabond CosmicVagabond is offline
Vehicle: 2009 Dodge Ram 1500 Crew
Color: Austin Tan
Rep:70
CosmicVagabond will become famous soon enough
Originally Posted by topgun View Post
Never thought of that. So you can see the brakes continue to be applied when on a hill and you take your foot off the brake? That would mean it is indeed receiving info from the truck's systems.
I've got everything ready to install in my 09. Got the 2 harnesses made up and connected to the controller. Just need it to stop snowing so I can plug it into the truck.
So you had to have a harness made to use the '10 brake controller in your '09?
Old 02-18-2010, 04:55 PM
topgun's Avatar
topgun topgun is offline
Vehicle: 2012 Ram 2500 CC 4X4
Trim Level: Outdoorsman
Rep:71
topgun will become famous soon enough
On the 2010, you can plug in the controller. On the 2009, you have to wire it in yourself. There are no plugs installed on the harness. It is very important to connect to the correct wires or you could do some serious damage.
There are 2 plug connections on the controller. You can buy the larger one that fits from Mopar but the other is not available. So I just made my own with some terminals I had. The larger connector wires (4) connect to the pigtail that fits into your blue plug under the dash. (same as any aftermarket controller) The smaller connector wires (3) need a connection to power it up and to the can bus c + and -.
Undercover SE, Corsa Cat Back, Amp Powersteps, Amp Bedstep, Bedrug, Mopar Tailgate Lock, Mopar Fold Flat Floor, Mopar Flat Rubber Splash Guards, Cooper AT3 285/70/R17's, S&B Intake, Moroso Catch Can
Old 02-19-2010, 01:00 AM
Yotaman96 Yotaman96 is offline
Yotaman96 is on a distinguished road
I installed the factory controller tonight. I think I got a bad one. The + and - button doesn't seem to funtion properly. The button feels very loose. Once hooked up, I could lower the numbers by hitting -, but I could not raise them. Also tried with a trailer hooked up and it still would not let me raise the setting.
2010 Ram 1500 Crew Cab 4x4 Sport
Old 02-19-2010, 06:51 AM
Cormacs's Avatar
Rep:14
sounds like a defective box
Old 02-25-2010, 10:00 AM
RKW RKW is offline
Gender: Not Specified
RKW is on a distinguished road
Have put the controller in my 2010. Went to rent a travel trailer and when they checked the brake output there was no voltage when the brakes were applied or levers squeezed together. They just saw the LED flashing dimly on the test plug they plugged in. Flashing rate or brightens did not change when brakes applied. Did the dealer have to flash the system after the unit was installed to make it work?
RKW
Old 02-25-2010, 03:01 PM
Cormacs's Avatar
Rep:14
The brake controller will not work with a tester. The brake controller will only work with actual working trailer brakes connected. No the dealer does not have to flash anything. I just plugged mine in and away I went. Connect the trailer and test it, I bet it will work.
Old 02-25-2010, 08:59 PM
RKW RKW is offline
Great news, thanks. Will try that.
RKW
Old 02-25-2010, 11:25 PM
topgun's Avatar
Rep:71
Just a note, the controller did not operate properly in a 2009 truck. The circuits I had to tap were the exact same ones as the 2010. Must be missing some of the software or something. Too bad as it solved the problem of where to put a controller when you have a console.
My controller went to a guy with a 2010. He said everything seems to work fine except the EVIC of course. One note though, he said that when he lets off the brake, the controller voltage goes to zero meaning it wasn't holding. Do you have to be in tow haul for it to function? The incline he was on was pretty steep.
Old 03-04-2010, 07:34 PM
cyberbiker cyberbiker is offline
cyberbiker is on a distinguished road
Anyone have any pictures of the installation process?
