Old 04-10-2010, 07:39 PM
Luke's Avatar
Luke Luke is offline
Trim Level: SLT plus
Rep:20
Luke is on a distinguished road
Default part 2, integrated brake install
here is the second part of integrated brake install part one is directly under this one, sorry for the mix up i didn't realize i could only get ten pics in till it was to late and didn't want to have to start over.
Please go easy on the criticism, I am not a mechanic or computer wiz just trying to help.
11- remove screw to existing trim ( found on side of dash by drivers door)
12- remove screw 2 to existing trim (to the right of and just above existing trim)
13- remove trim
14- install new trim with module, add screws that where removed from old trim to fasten new trim and module, free the 2 connectors from the wiring harness and plug the connectors into the module, this may prove a little inconvenient because it's cramped under the dash.
reinstall side panel and under panel ( don't forget to use screws you removed)
15 the finished product
Old 04-11-2010, 08:27 PM
Luke's Avatar
Rep:20
I sure hope that brake works the way it should.
Camping season is almost upon us and I'm gonna have to hook up the camper it's a 32 foot 9600 lb Jayco tag along trailer and if that brake don't work I'm gonna have a problem, and yes I will test it first LOL. gotta say what a way to test the new truck my only fear is when i bought the truck i should have bought 392 gearing and I got 355's cause the truck i wanted didn't have the 392's and it was a 12 week waite and I couldn't wait, the haul is only 1.5 hrs from the site and i was told there was nothing to worry about as long as i didn't leave for a 3 day journey. We have a seasonal lot.
We're gonna find out.
Old 04-13-2010, 08:11 PM
RJG RJG is offline
Color: Mango Tango
RJG is on a distinguished road
I stopped by my local Dodge dealer to order the brake controller. They told me there are several hundred on back order, with no known availability date. Supposedly there is an issue with faulty brake controllers? Does anyone know more about this?
Old 04-13-2010, 08:20 PM
Cormacs's Avatar
Cormacs Cormacs is offline
Trim Level: Crew Sport
Rep:14
Cormacs is on a distinguished road
I havn't heard anything about it and I work at a dealer. Some times they assume a part is faulty because the part is on back order. Really a part being on back order doesn't mean much. It can be on back order 700 but you could still get it in a week. I wouldn't worry about it.
Old 04-13-2010, 09:37 PM
Luke's Avatar
Rep:20
I ordered mine and was told it could be a 2 month wait and 2 weeks later it was here 2 days later it was in.
Old 04-16-2010, 10:44 PM
clatla's Avatar
clatla clatla is offline
Color: Snow White
Rep:31
clatla is on a distinguished road
This is an great post! Thanks to all that have gave input!
Old 04-16-2010, 10:46 PM
Rep:1625
Welcome to the forum, we're glad to have you here. Go ahead and introduce yourself in the "newbie checkin" section. We'd love to hear about you and your truck
Old 04-17-2010, 11:49 PM
RAMBS RAMBS is offline
Vehicle: 2010 Ram
Color: Blue
RAMBS is on a distinguished road
I ordered mine and it was in in a week. $223.00 installed. I'll be hooking up my 28" Jaco tomorrow.
Old 04-19-2010, 12:59 PM
Dodger D Dodger D is offline
Vehicle: 2009 Dodge Ram 1500 SLT QC
Trim Level: SLT Bighorn
Color: Mineral Gray Metalic
Rep:15
Dodger D is on a distinguished road
On my 2009 1500 SLT, I mounted the Tekonsha P3's tiny bracket onto the dash above the left, center cup-holder, (full front bench seat version). Only two small holes need to be drilled for the mounting screws. These can be covered with two small SS Phillips-head screws when dis-mounted - very unnoticeable. The advantage is, the visibility and access for manual-braking is excellent, and your leg-room is unaffected. I decided the usability and safety aspects of having the controller fully visible & accessible far out-weighed drilling a couple of holes in the dash. (It's a TRUCK after all...)
Old 04-19-2010, 01:30 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
I just mounted my Tekonsha in the factory location. It doesn't look as nice as the factory optioned one but I think it'll work. I removed the piece of trim then used a dremel, file and utility knife to cut out the back of the panel. The controler fits so good/tight I didn't have to drill any holes and the harness plugged right in. It sticks out about 1.5"s...just enough so I can use the buttons/controls but not so much where I hit my knee on it b/c of how high the location is.
