Old 04-19-2010, 03:01 PM
Dodger D Dodger D is offline
Vehicle: 2009 Dodge Ram 1500 SLT QC
Trim Level: SLT Bighorn
Color: Mineral Gray Metalic
Rep:15
Dodger D is on a distinguished road
To Gabrieldy, Very nice! I looked at that area, but decided that my old eyes wouldn't be able to see the display as well, so I opted for my raised installation as explained in my prior post.
By the way, I just towed a 2007 25ft Airstream for two weeks and the truck and the P3 performed flawlessly. - DodgerD (2009 Hemi, w/ 3.55gears & 20"wheels - slightly over-weight, but easily capable. Max Trailer Weight for this config is 6400lbs, trailer loaded weight is 7300lbs, I just kept it light.)
And, for those who are curious, you can order the correct Dodge to P3 clip-in interface harness when you order the P3. I purchased both on Amazon.
Old 04-19-2010, 07:05 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
DodgerD thanks for the feedback. You should post up a pic if you have one. Might help give others some ideas. BTW I ordered mine from e-trailer b/c the Dodge harness was included.
Good to hear how well it tows. I have the same gear/wheel setup but will only be towing my Roush on a flat trailer (maybe 5000 lbs for both).
Old 04-20-2010, 09:55 PM
RJG RJG is offline
Color: Mango Tango
RJG is on a distinguished road
I ordered the unit from another dealership. Hopefully it will show up soon.
Old 04-22-2010, 11:50 PM
stinkyteeth's Avatar
stinkyteeth stinkyteeth is offline
Vehicle: 2010 Dodge RAM
Rep:62
stinkyteeth will become famous soon enough
Default the white clips
Here's a newbie question for ya.... take out the screws, then how do you remove the white plastic clips (that hold on the panels) without wrecking them?
Thanks for the pictures of the screw locations....ready to tackle this as soon as I get the clips figured out.
Old 04-22-2010, 11:54 PM
CHVYKLR's Avatar
Rep:252
After removing the 2 screws you should just be able to pull the panel towards the seat.
Old 04-25-2010, 04:15 PM
Luke's Avatar
Luke Luke is offline
Trim Level: SLT plus
Rep:20
Luke is on a distinguished road
gabreildy is right just pull gently towards the seat and they will come free,
Old 04-25-2010, 08:40 PM
Mathman45 Mathman45 is offline
Vehicle: 2010 Ram 1500
Color: Blue
Mathman45 is on a distinguished road
Angry Problems with P3 controller
Has any one tried to install a Tekonsha P3 controller. I plugged it in, it gave an battery short error. Left it plugged it to research it, came back the unit was so hot I could hardly touch it
Any Ideas
Old 04-25-2010, 09:02 PM
CHVYKLR's Avatar
Rep:252
Sounds weird. I would try to unplug it and call them tomorrow. I haven't towed anything since installing mine so the display always shows the two dots which indicate that is has power and no trailer is attached.
Another thought...did you get the Dodge specific wiring harness with it that is plug and play or did you try to wire it up? I'll break out the troubleshooting section from my manual in the meantime.
Old 04-25-2010, 09:12 PM
Color: Blue
i bought the Tekonsha harness #3021-p They said that is the one I needed. But now they do not offer the harness that I can find. Sound suspect to me
Thanks for the reply
Old 04-25-2010, 11:12 PM
CHVYKLR's Avatar
Rep:252
That might be the problem. My part number was 90185-3020P.
