Old 10-22-2009, 05:15 PM
2009Cummins's Avatar
2009Cummins 2009Cummins is offline
Vehicle: 2009 dodge ram 2500 cummins
Trim Level: big horn
2009Cummins is on a distinguished road
Default Need help asap emergency
hey i took my silencer ring off the turbo and it chipped the turbine wheel and i just want to make sure its not gonna desintugrate on me it was just a corner on the outside of one of the "fins" mabye 1-1.5cm long...still boosts fine i just need reasurance itll be fine....
Old 10-22-2009, 08:42 PM
Cross your fingers . Thats all I can say . They do spin up some rpm . Hopefully it isn't out of balance . If a problem develops , put the ring back on and take it in for warranty work . " I don't know whats wrong with it "
Old 10-22-2009, 11:08 PM
boostjunkie1's Avatar
boostjunkie1 boostjunkie1 is offline
Vehicle: 2008 Hemi Ram
Rep:62
boostjunkie1 will become famous soon enough
Oh NO.... You are looking at a new turbo in about 6 to 12 Months .... ..... Just think about that front wheel that is a little bent and is running at 400 Revolutions Per Mile. ...... It makes the front end and steering wheel wobble a little right????? Now that that 400 and make it 400,000 per mile! Wont last that long! I have talked with a couple people that have done this and we now call them MAY POPS.... May POP today.....May POP tomorrow..... BUT SHE WILL POP GOOD LUCK!
** Installing the ring and taking her back to the dealers will probably not work. You have a marking on the silencer ring that will have to be back in the correct position or they are going to know that you moved it....... Still worth a try!
What are you going to tell them??????
Old 10-22-2009, 11:09 PM
Rep:62
Get a new Compressor Wheel and have it installed before the explosion ends up in your engine!!
Old 10-22-2009, 11:44 PM
I push the skinny pedal
Rep:3277
You'll have a bad time when that spool piece goes. In university (aerospace structural engineering) we did destructive testing on supercharger rotors and a small imperfection ANYWHERE in the blade will cause it to fail 90% of the time, and they don't just go quietly into the night. You'll end up with shrapnel thourgh your engine and be looking into a WHOLE bunch of work to fix that.
Try reinstalling the silencer ring and see if the dealership will warranty it, if yes, celebrate, if no, but a new blade, and then celebrate for the sake of.
Kurtis
Old 10-23-2009, 01:06 PM
OK so i went to the dealer they inspected it and gave it the OK its not vibrating its spooling and boosting just fine... and if it goes they are going to cover it... i just told them it must have been messed with before i bought it...
Old 10-28-2009, 09:24 PM
2nd Ram's Avatar
2nd Ram 2nd Ram is offline
Vehicle: 2009 Dodge Ram 1500 4X4
Color: Black/Gray
Rep:14
2nd Ram is on a distinguished road
I kinda think I'd get the dealer to replace the turbo now if he will, before the thing blows and you're left stranded or without a ride. Remind the dealer that all it needs now is the turbo. If they wait till it flies apart, they may be replacing/repairing much more!
Old 10-29-2009, 03:59 PM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
it shouldn't explode into a million pieces. People do that on my starquestclub website all the time (starion/conquest).
What will probably happen, is, if its out of balance, it causes the shaft to wobble a little, and what will eventually happen, is, it will blow the internal oil seal out, causing a lot of smoke, and, you should shut it off pretty quick before all the oil is forced out through the seal. (if your engine oil is also the turbo's oil, anyway)
But...you would have to actually suck something into the turbo for it to explode.
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
