Old 10-11-2009, 10:47 PM
bigbass19 bigbass19 is offline
Vehicle: 2001 Dodge Ram 1500 Sport
bigbass19 is on a distinguished road
Default Water on passengers side floor
I have been having water or some sort of fluid pool up on the passengers side floor. I can't tell where it is comming from. Anyone know what this could be and what I can do to stop it? Thanks
Old 10-11-2009, 10:52 PM
bigrammer's Avatar
bigrammer bigrammer is offline
Vehicle: 2000 Dodge Ram
Color: Blue
Rep:27
bigrammer is on a distinguished road
Sounds to me like a heater core leak. I would check to see what your antifreeze level is and if it is low try filling it up and putting some stop leak in it. I had a 1997 jeep wrangler with a leaking heater core. tried the stop leak but didnt work so i had to replace the core. Just let me know if you need anymore info
Old 10-11-2009, 10:56 PM
Sparky's Avatar
Sparky Sparky is offline
Vehicle: '06 Ram Quad Cab HEMI
Color: FLAME RED
Rep:23
Sparky is on a distinguished road
replacing the heater core would be better than stop leak IMO.
Old 10-11-2009, 11:03 PM
Zekery360 Zekery360 is offline
Vehicle: 2002 Dodge Ram
Color: Bright Red
Zekery360 is on a distinguished road
^^^ I agree with what everyone else is saying. If the fluid smells "sweet", then it is most likely coolant. Also, check your coolant level. If it is low, it is also a good indicator. To do a heater core however is a huge job. If you are mechanically inclined, go for it, otherwise you may have to bring it into a Dodge dealership.
Old 10-11-2009, 11:13 PM
Great, I am mechanicly inclined, but haven't done to much with trucks. How much should I be looking at if I have someone do it? Thanks for the help. I am lossing fluid out of radiator. Thanks
Old 10-11-2009, 11:21 PM
Rep:4072
My thought exactly. Hopefully you know someone who can do the work at a fair price or are you having to go to the dealership?
Old 10-11-2009, 11:25 PM
Sparky's Avatar
Color: FLAME RED
Rep:23
I am mechanically inclined and I have done it myself on a GMC Jimmy before. It is not that hard, but I would get some kind of service manual that can give you a step by step. This project takes time, so it might cost you to have some one do it for you but it is not hard to do yourself.
Old 10-12-2009, 09:55 AM
08quadram's Avatar
08quadram 08quadram is offline
Vehicle: 08 Ram Quad 1500
Color: silver
Rep:22
08quadram is on a distinguished road
Before you replace your heater core. Check your drain line for the air conditioner condenser. That would be my first guess. I'll bet it is plugged up or no longer sticking thru the firewall. If your noticing that your radiator is losing water, you must have a fairly large leak then and it would smell sweet, the windshield would fog over also. If you don't smell anything, its your air conditioner condenser drain line.
Mike
'08 1500 Ram, Quad 4x4 Bighorn, Silver, 20" wheels, 5.7 Hemi/MDS, 3.92 axles
"Meddle not in the affairs of dragons, for thou art crunchy and good with catsup" -Doc, IFSJA
Old 10-12-2009, 06:44 PM
Color: Bright Red
See, the problem with stop leak is that while it plugs up your leaks, it plugs up everything else too. I guess its an ok short term fix. Very short term.
Old 10-12-2009, 09:24 PM
See your in (hot , steamy) Texas . Do you use your A/C ? If so , it could be a clogged evaporator drain . When your A/C is on and the drain is not clogged , you see the puddle under your truck , thats from your A/C drain . It could be a bad heater core also . Our trucks were notorious for bad heater cores and also bad evaporators . If it's determined that you have a bad heater core , I would suggest to you , while your there to replace the A/C evaporator also . I have replaced the heater core on my truck twice . One was leaking , the other was defective . Been great for several years , but now my evaporator is leaking . Should of taken my own advice . I'm not a believer in stop leak . It has a tendency to clog up things that shouldn't be clogged up . If you do your heater core , change out your coolant also . Do not reuse it . My coolant was nice and green but there is a test for testing electrolysis . If you have bad coolant it will eat pinholes in your radiator , heater core etc...If I can find my info on the testing procedure I will post it . Anything I can help you with let me know or just ask away .
