Old 10-06-2009, 08:58 PM
Husker1111's Avatar
Husker1111 Husker1111 is offline
Trim Level: TRX 4
Rep:193
Husker1111 has a spectacular aura aboutHusker1111 has a spectacular aura about
Default Cuttin off the cats?
ya so ive been considering cutting off the cats and just putting a straight pipe there so i have a make shift exaust. I know I know its illegal but what u guys think? Do you think it will sound good?
2010 Dodge Ram 1500 white TRX4, 2" leveling kit, Nitto Trail Grapplers 35x12.5R20, Painted stock wheels off 08 Black, 20% tint on front windows, painted to match fender flares and bumpers. University of Tampa
Old 10-06-2009, 09:02 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
It may sounds good, but the truck may not like it. Should do some research and make sure the o2 sensors won't be affected by it.
Old 10-06-2009, 09:14 PM
CHILLZ HEMI's Avatar
CHILLZ HEMI CHILLZ HEMI is offline
Vehicle: 2008 Dodge Ram 5.7L HEMI
Trim Level: Big Horn, Quad Cab
Rep:47
CHILLZ HEMI is on a distinguished road
Send a message via AIM to CHILLZ HEMI
yeah, and that might actually make you lose power because of the loss of backpressure...
Old 10-06-2009, 11:12 PM
I push the skinny pedal
Rep:3277
I wouldn't recommend it either. The fuzz is getting wise to trucks like that and having them towed if they pull you over (they like to check if your exhaust is loud). In addition to the problems that may arise from your O2 sensor and the above mentioned backpressure issues, I'd probably throw highflow cats in instead.
Kurtis
Old 10-07-2009, 12:02 AM
Sparky's Avatar
Sparky Sparky is offline
Vehicle: '06 Ram Quad Cab HEMI
Color: FLAME RED
Rep:23
Sparky is on a distinguished road
Highflow cats work good and make your truck sound sweet.
Old 10-07-2009, 12:18 AM
Johnnyhemi Johnnyhemi is offline
Rep:14
Johnnyhemi is on a distinguished road
Just want to clear this up, That statement is a myth and a myth only, it is greater to have less backpressure on the cylinders during an exhaust stroke, thats why headers were invented to actually make a vaccum from the combustion chamber during an exhaust stroke, the easier it is to move spent gasses the more power the engine will make. What it can potentially do is make you run exccessively rich in 3rd gear because the pcm already enrichens the mixuture in 3rd gear to protect the cats from a heavy load as well as pistons. Removing the cats could make the pcm adjust to protect them even further because they are now gone and upstream and downstream voltages will no longer match those of a system with cats. This can be tuned "out" with a custom tune like SCT or Diablo
spartan max cam,sharadon valvebody,srt10 d60 w/4.10s,hedman LTs,SCT Hemifevertuned,much more
Old 10-07-2009, 07:27 AM
SeaWolf SeaWolf is offline
SeaWolf is on a distinguished road
Not sure about Dodge but many late model vehicles require exhaust back pressure to operate the egr system. If it doesn't see back pressure on the egr valve it never opens so the pcm doesn't see that lean condition and thus goes into "limp mode" and turns on the MIL. I did install straight duals on a Suburbon 350 V8 and have not been able to rectify that situation, yet. Not that u will have this problem but something to consider.
Old 10-07-2009, 08:35 AM
kineticenrage kineticenrage is offline
Vehicle: 2005 Ram
Rep:17
kineticenrage is on a distinguished road
i had header and no cat with a straight pipe exhaust on my eclipse. if it's all the same with the 4 cylinder. it ran a lot smoother and faster than stock. i was throwing an o2 senor code but just deleted it and never had any more problems.
Old 10-07-2009, 09:23 AM
Rep:47
Oh, well thats good to know then, ive never heard of that...Either way, I wouldnt just cut them off, put high flow cats on and stay legal, or like it was said above, you get pulled over, plan on walking home....
Old 10-07-2009, 09:26 AM
chithead's Avatar
Rep:2078
High flow cats!
