Old 10-23-2009, 05:43 PM
Sparky's Avatar
Sparky Sparky is offline
Vehicle: '06 Ram Quad Cab HEMI
Color: FLAME RED
Rep:23
Sparky is on a distinguished road
I know when I have messed up electrical problems, most the time it is a ground problem somewhere.
Old 10-23-2009, 07:53 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Originally Posted by Toms Blue Ram 1500 View Post
Stranger things have happened . Easy test here . You have the good bulb you took out of the left front . It is a good bulb . We know that . Plug that in the R/F and see if it works . I have seen brand new bulbs out of the box be defective . If the bulb from the L/F still doesn't work then we have a power or ground problem which you need a voltmeter . Let us know how you make out . If you still have a problem let us know and we''ll go to the next step . Tom
Gotta love the simple fixes!!
Old 10-23-2009, 08:24 PM
CHILLZ HEMI's Avatar
CHILLZ HEMI CHILLZ HEMI is offline
Vehicle: 2008 Dodge Ram 5.7L HEMI
Trim Level: Big Horn, Quad Cab
Rep:47
CHILLZ HEMI is on a distinguished road
Send a message via AIM to CHILLZ HEMI
And you had a mechanic look over the whole wiring harness that is part of the headlights, and turn signals??? And all the wires were good???
Old 11-20-2009, 09:31 AM
Jasser's Avatar
Jasser Jasser is offline
Vehicle: 2006 Dodge RAM 1500 4x4
Color: Mineral Gray
Jasser is on a distinguished road
OK... Found the issue with the Passenger Low Beam not working.
My Mechanic looked it over with this new tester he got.
Bulb is good, wire is good, all fuses are good.
The problem? The "Totally Integrated Power Module". Part's price is at $689 canadian. He can get one for me at cost for $599. Either way, not cheap!
Why the heck would one of these fail? this truck's 3 years old!
Anybody else had issues with this thing? Anyone hear of recalls on this part?
Fack....
Old 01-08-2010, 08:48 PM
leroycool1 leroycool1 is offline
leroycool1 is on a distinguished road
hi
i am new here
i came on here looking for info on this same problem
a guy at work has that same problem its a 2007 1500 with a hemi it started about a month ago and he has not done anything about it yet
and today my dad said he had the same problem on a 2007 3500 cummins i dont think i want to tell him the problem is $600 + to fix
i hope mine does not do this HAHA its a 2007 1500 hemi
Old 01-09-2012, 09:30 PM
powers07ram powers07ram is offline
Vehicle: 2007 dodge ram 1500
Trim Level: sly thunder road
Color: blue
powers07ram is on a distinguished road
i am having kinda the same problem but my left side low beam is out and everything else works fine l and r high beam and r low beam works fine
Old 02-01-2012, 11:32 AM
h2oman226 h2oman226 is offline
Vehicle: 2006 Dodge Power Wagon
h2oman226 is on a distinguished road
i replaced my TIP years ago, prob around 2009 when my truck was 3 yrs old. Back then, it was causing all sorts of mysterious gremlins, but none effecting the headlights.
So fast forward 3 years to present day, Now my drivers headlight functions in dim, but not bright. The passenger side works as designed.
I've replaced the bulb, checked the harness, and did not see any blown fuses.
For about 6 months, the bright drivers light would intermittently come on/off as i drove down the road. Random, didn't seem to be effected by weather, road bumps etc. Now, no bright at all on that side.
Related, I have a Western Ultramount plow setup i use on this rig. Sure enough, i've hooked it up, and i have no bright on the drivers plow light either, which is all wired into the main box under the hood.
If the TPI has gone bad again, i'm going to flip. i may just consider jumping the lead from the passenger side over to the drivers side to save myself the $800.
Any tips?
