Old 10-13-2009, 08:39 PM
jgorilla's Avatar
jgorilla jgorilla is offline
Vehicle: 1995 ram 1500 2007 charger sxt
Color: red, grey
Rep:29
jgorilla is on a distinguished road
Default Anyone using 3" lowering blocks
if i use 3" blocks and 2" hangers. will that give me a total of 5 inches?
same fight different round
Old 10-13-2009, 09:07 PM
I push the skinny pedal
Rep:3322
What year is your truck? And I don't know if i'd use them in conjunction with eachother, would seriously hamper your suspension I think.
Kurtis
Old 10-13-2009, 09:12 PM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
this sounds like a personal problem
jk...lol
Actually, what year truck are we talking about? Is this with leaf spring suspension, I'm guessing? If so, depending on how this works, you may have to add in the thickness of the springs...but, I'm not sure how you're doing it exactly.
Also...someone with a little more knowledge in this should chime in
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
Old 10-14-2009, 03:53 PM
bigjeff64's Avatar
bigjeff64 bigjeff64 is offline
Vehicle: 2001 Dodge Ram Quad Cab
Rep:20
bigjeff64 is on a distinguished road
keep in mind that lowering blocks were not designed for the bigger trucks!! They originally were designed for the blazers and s10, sonomas, rangers etc etc etc!!! I know several local shops that would advise against lowering blocks. A flipkit would work best but keep in mind that depending on the condition of the roads a flipkit without a c notch will destroy ur axle even with smaller bump stops. Do your HOMEWORK!!!!!!!!
Shackles and hangers would give u a 4 inch drop on back without risk or notch!!!!! just a suggestion
